Finished Drywalling The Basement - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-10-2011, 09:15 PM   #1
MikeKy55's Avatar
Rewards Points: 254
Finished drywalling the basement
The end I thought would never come has arrived . The drywall is all finished. My assessment is if you were shooting for a level 4 finish and were judging on a 1 to 10 scale, I put mine at about 8 to 8.25. I can see seams on the ceiling (smooth finish) if I remove the curtian on the basement window and stand at the opposite end of the room. But if the lighting is from the overhead lights only, I can't see them. I only have the ceiling painted so far, so the jury is still out I guess. However, I don't think the walls would show as much as the ceiling since you can't get the same lighting on them as I did on the ceiling.
I wanted to thank all the folks here for their help.
I still have quite a bit more work to do before this project would be considered done. Doors, trim, tile in the bath etc., but it's coming along.
MikeKy55 is offline   Reply With Quote
The Following User Says Thank You to MikeKy55 For This Useful Post:
oh'mike (07-15-2011)
Old 07-13-2011, 06:17 PM   #2
Rewards Points: 150
congrats, post up some pics for us to look at.
stradt03 is offline   Reply With Quote
Old 07-14-2011, 09:42 AM   #3
MikeKy55's Avatar
Rewards Points: 254
Not very detailed, but they give you an idea.
Old 07-15-2011, 05:44 PM   #4
Rewards Points: 150
Looks good! thanks for posting
The Following User Says Thank You to stradt03 For This Useful Post:
MikeKy55 (07-15-2011)
Old 07-15-2011, 05:58 PM   #5
DIY staff
Rewards Points: 7,174
Looks good----post more when you get to trimming it.---Mike---
Old 07-16-2011, 04:20 PM   #6
Drywall contractor
Rewards Points: 1,070
Nicely done!
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
The Following User Says Thank You to bjbatlanta For This Useful Post:
MikeKy55 (07-16-2011)
Old 07-19-2011, 10:08 PM   #7
Looks good. That's a lot of drywall area and corners galore.
speedtree is offline   Reply With Quote
Old 07-19-2011, 10:26 PM   #8
Rewards Points: 558
Was this your first attempt at dry walling? If it is, you did a great job…
epson is offline   Reply With Quote
Old 07-20-2011, 09:47 PM   #9
MikeKy55's Avatar
Rewards Points: 254
First time on this scale. I have done less challenging drywall jobs for myself over the years. I had a house that was built in 1954 and someone over the years converted a bedroom that was next to the kitchen into a dining room. When they did, they removed a load bearing wall. It didn't occur to me for a couple years. I found it when I removed the paneling they used to cover up all the crap. There was originally a closet against that load bearing wall as well. When they tore everything out, they left very large holes in the sheet rock walls ( I called it sheet rock because it was 12 inch high strips made of concrete and plastered over. Metal mesh at the corners and wall seams at the ceiling) So I wrapped the room in 3/8ths drywall. Before that I put a beam across the opening where the load bearing wall was. My home office was above that room. I never noticed how soft the floor was in my office until I put that beam up. Later that day I went upstairs and when I walked into my office I stopped in my tracks. The floor felt so much more solid it was noticeable.
Partially finished Basement HVAC l22 HVAC 1 01-24-2011 12:22 PM
Below Grade Finished Basement Stays Around 55 Degrees diyourselfer Building & Construction 9 02-26-2009 07:11 AM
Basement finished with Low Ceilings and no permit missy22 Remodeling 11 01-30-2009 06:20 PM
Low ceiling finished basement pics SAGENT General DIY Discussions 1 01-22-2009 11:46 AM
Finished Basement Remodel Questions bioguy Remodeling 6 11-15-2007 09:56 PM
