Filling And Re-drilling A Ceiling Hole? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By SPS-1
  • 2 Post By joecaption
Old 08-27-2016, 05:59 PM   #1
Rewards Points: 6
Question
Filling and re-drilling a ceiling hole?
This morning my curtain rod became loose and fell out of the holes drilled into the ceiling, the holes are too big now and I want to fill them in and put the curtains up in the same place. Placing the holes somewhere else isn't an option.
I was wondering what kind of filling will be strong enough to keep the screws/anchors from falling out again?
melodymaru is offline   Reply With Quote
Old 08-27-2016, 06:15 PM   #2
Rewards Points: 4,266
Re: Filling and re-drilling a ceiling hole?
Hi Melody and welcome to the forum.
Anchors in drywall are never very strong. Since you can't relocate it there are a couple of options, but I don't know how big the hole is now. If it is just where the anchor pulled out you can squeeze the hole full of a one part adhesive that hardens solid. I've used construction adhesive for many repairs but it cures very slowly. There are 2-part epoxy materials that would cure in 20 minutes, but you would have to get innovative to squeeze then into place. I'm thinking of a piping bag used for cake decoration, could work. Once you fill the hold then drill a new hole and use your anchor.
Another approach would be a different style anchor, one that has metal fingers that expand and capture the back of the wall. They use a slightly larger hole to start so may not need to patch.
Got a picture??
Bud
Bud9051 is offline   Reply With Quote
Old 08-27-2016, 06:33 PM   #3
Rewards Points: 1,453
Your curtain rod is screwed into the ceiling? That is a little odd. Try a toggle bolt.
Squeeze the wings together and push it through the hole. Then they will pop open inside the wall. No way to pull them out. It's possible that the drywall just doesn't have the strength to hold that weight, but then you have bigger problems.
mathmonger is offline   Reply With Quote
Old 08-27-2016, 06:33 PM   #4
Rewards Points: 2,638
If the anchors were the type on the left, see if the anchor style on the right will fit. They typically need a bigger hole, and are much stronger anyways.
jeffmattero76 likes this.
SPS-1 is online now   Reply With Quote
Old 08-27-2016, 07:14 PM   #5
Rewards Points: 6
The anchors we have right now are indeed the ones on the left, we are going to try the ones on the right right now. Here's hoping!
Old 08-27-2016, 07:37 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
Snap toggles
https://www.amazon.com/Toggler-Snapt...s=Snap+toggles
Coastal South Carolina
Old 08-28-2016, 08:32 AM   #7
Rewards Points: 14,020
Post a picture of what you have now.
Trying to picture why you have it just attached to drywall, and why the ceiling of all places.
Just not a great way to do it.
Old 08-28-2016, 09:34 AM   #8
Rewards Points: 6
Unfortunately that's the way our apartment building has decided to do it.
We have also discovered that the ceiling is concrete underneath the plaster and it seems very difficult to get the screws back in ourselves, so I think we will just have to get someone from the building to come in and fix it for us.
Thank you everyone for all of your help though! It's too bad we couldn't fix this ourselves
Old 08-28-2016, 09:05 PM   #9
If it's concrete then Tap Con Screws should have been used.
Those cheap plastic anchors are the first thing I throw away on anything I have to install, there useless.
jeffmattero76 and ReelDeel like this.
Filling a Hole in the Bathroom Ceiling Zee in BK Kitchen & Bath Remodeling 2 06-28-2014 06:26 AM
Help filling chimney hole in foundation Squints Concrete, Stone & Masonry 3 06-17-2013 10:59 PM
fix wrong hole while drilling concrete elcool Concrete, Stone & Masonry 8 05-19-2013 02:18 PM
Filling in Stud hole mysticguy Drywall & Plaster 3 05-21-2012 07:51 PM
Filling a large hole in basement! rotteneggz Building & Construction 4 10-01-2010 06:11 PM
