Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 07-20-2012, 02:56 PM   #1
Filling joints before taping
I have a few panels that need to/should be filled before I start to tape (due to my crummy drywalling).
Which of these two should I use for this?
Was thinking this:
http://www.cgcinc.com/en/products/jo...aspx?pType=PRO
But looking at their website I should maybe use AP?
Any input is appreciated.
Thanks,
Mitch
MLayden is offline   Reply With Quote
Old 07-21-2012, 12:57 AM   #2
Moderator
4.6.7.1 and 4.6.7.2; http://www.lafargenorthamerica.com/G...%20English.pdf
You can also try our "Search" box at the top of pages for subject lists of past discussions. Type in white box...
Gary
Clothes taking longer to dry?
The Following User Says Thank You to Gary in WA For This Useful Post:
MLayden (07-24-2012)
Old 07-22-2012, 06:50 PM   #3
For pre-filling gaps prior to taping?
I use a setting compound, IE 20 minute mud, or concrete fill (the stuff used for drywall work)
chrisBC is offline   Reply With Quote
The Following User Says Thank You to chrisBC For This Useful Post:
uneven hardy board joints after taping Jt12 Flooring 1 11-19-2011 06:14 PM
taping OSB sheathing joints George Walker Building & Construction 37 01-18-2011 06:02 AM
Filling Joints between Flagstones blue_can Building & Construction 4 09-11-2010 01:28 AM
taping hardibacker joints. cure time? tarheelblue Flooring 2 01-23-2010 01:18 PM
Crack filling concrete control joints MI-Roger Building & Construction 11 09-22-2009 07:00 AM
