Filling Hole Around Heating Pipe - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-11-2012, 11:36 AM   #1
Filling Hole around Heating Pipe
Hi,
I have a hole in my ceiling that is roughly the size of a kiwi and is located along the side of a heating pipe. The pipe can get very hot during the winter.
How should I go about filling this hole? I was thinking about using some Spackle or plaster but I worry about its contact with the hot pipe.
Any suggestions?
oldmanwinter is offline   Reply With Quote
Old 05-11-2012, 05:07 PM   #2
Rewards Points: 1,062
kiwi sized is too big for spackle. i think you will need to saw the drywall on at least two sides of the whole to find the nearest framing studs to which to fasten the patch with screws.
do you have pictures?
Old 05-11-2012, 05:43 PM   #3
if there are no studs nearby, you can also widen the whole with a drywall saw to form a regular shape (e.g. a square), then take two pieces of 2x4 slightly longer than the side of the square and put them in the back of the hole along the top and bottom side of the hole, half the width behind drywall and screwed from the front, the other exposed in the hole (so that you can screw the patch to it). that's the way i'd do it.
Old 05-11-2012, 11:24 PM   #4
Registered User
Rewards Points: 5,514
This "heating pipe", is it a gas flue vent that would require a shield around it of non-combustible material: http://publicecodes.citation.com/ico...026_par003.htm
Describe it please, before you install paper-backed drywall which is flammable....
Gary
P.S. Welcome to the forums!
Tags
filling holes , plaster
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
Septic Odor from Hole in Copper Pipe kita123 Plumbing 1 04-03-2012 08:22 PM
Question about moving heating vent pipe randalg HVAC 4 03-15-2012 03:24 PM
heating pipe bstinkenmo HVAC 4 01-12-2011 08:38 AM
Exterior Furnace exhaust vent pipe NeedHomeRepair HVAC 1 12-20-2010 05:17 PM
