Filling Gap In Drywall Corner - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-27-2009, 04:57 PM   #1
listo's Avatar
Rewards Points: 95
filling gap in drywall corner
i just put new drywall up in the bathroom ceiling and the room isn't square so i measured everything to cut the drywall the right size.
Unfortunately i measured then forgot to flip it to go upside down on the ceiling. So now i have a gap at each corner of the room. the one side is about an inch wide and the other is 5/8ths of an inch. and they stretch about halfway down the length of the wall until they meet with the wall.
So my question is, how can i fill these gaps?
Can i use expanding foam in there then cover it up?
listo is offline   Reply With Quote
Old 01-27-2009, 05:09 PM   #2
listo's Avatar
Rewards Points: 95
here's some pics
far away
and a close up
Old 01-27-2009, 05:34 PM   #3
Rewards Points: 1,910
You need to replace it with the right size but you also need a nailer along that edge. There's nothing holding that edge and if you try to patch it it will crack in no time.
Old 01-27-2009, 05:43 PM   #4
listo's Avatar
Rewards Points: 95
a nailer?
over where it's long enough it goes over the top. is that good enough?
Old 01-27-2009, 06:23 PM   #5
Time for some crown molding.
jerryh3 is offline   Reply With Quote
Old 01-27-2009, 08:35 PM   #6
Cosmetically crown molding would be a great way to cover that corner. However, as jogr said you'll probably want to secure that puppy down as crown would be strictly cosmetic and wouldn't really add to the structural integrity of the new drywall.
brcleeroy is offline   Reply With Quote
Old 01-27-2009, 09:29 PM   #7
BUILDER / REMODELING CONT
buletbob's Avatar
Yes agree you must install a nailer on top of that all. what is supporting the wall from moving, if this isn,t addressed and you fill the gap with new drywall to fit tight, you will have a crack along the ceiling line, there is no support. BOB.
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 11:16 PM
Drywall Corner Confusion Melanie337 Drywall & Plaster 5 01-18-2009 10:01 AM
drywall corner bead drewhart Drywall & Plaster 2 10-22-2008 10:28 AM
Butt Joints at new drywall and existing corner round VistaV Building & Construction 1 02-03-2008 10:36 PM
Drywall corner bead Question dk_99 Building & Construction 5 01-01-2008 04:25 PM
