Filling 2" Section On Plaster Background - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-29-2013, 04:19 AM   #1
Filling 2" section on plaster background
Hi,
I've removed a cable conduit which was fixed to the wall before the walls were plastered (not by me!). I would like to fill the gap with plaster to get a clean finish prior to painting.
I intent to sand the background and fill with plaster, however I was wondering if I need to reinforce the joint between the new plaster and the old?
Thanks for any help
fivetimes is offline   Reply With Quote
Old 03-29-2013, 07:18 AM   #2
Rewards Points: 13,458
Can you post a picture so we can see what it is you have to deal with?
Old 03-29-2013, 09:26 AM   #3
Old 03-29-2013, 09:28 AM   #4
The photo is a close up of a section of missing plaster after removing the cable trunking.
It's about 2 inches wide and 3 metres long, on the internal corner of a stairwell.
Hope that give a clearer picture.
Old 03-29-2013, 10:19 AM   #5
Rewards Points: 5,974
From what I can see there I don't you need to reinforce just a good fill. Are you going to use plaster patch or joint compound?
Old 03-29-2013, 10:33 AM   #6
Rewards Points: 744
I don't see the gap you're speaking of. I just see a hole.
Seattle2k is offline   Reply With Quote
Old 03-29-2013, 11:58 AM   #7
Thanks for the advice tool keeper.
I'll sand and make sure theirs a good key and then just fill with a plaster filler.
The Following User Says Thank You to fivetimes For This Useful Post:
ToolSeeker (03-29-2013)
Old 03-31-2013, 07:38 AM   #8
Plaster can not fill voids that size. Fill it with blue board then tape the joints and plaster it. Then you will need to add a tight coat of joint compound. If you try to use plaster to fill a gap that size it will fail, ie crack.
garywade78 is offline   Reply With Quote
Popcorn ceiling made of plaster strungoutfan78 Drywall & Plaster 12 10-31-2016 12:25 PM
Bathroom Remodel - Resurfacing Plaster over Concrete Block itcanadian Remodeling 2 05-30-2011 10:10 AM
Replacing Section of Sole Plate RM575 Carpentry 3 03-28-2010 09:31 AM
plaster / drywall sharp Drywall & Plaster 10 11-18-2009 10:10 PM
Texture to plaster bofusmosby Remodeling 2 05-05-2008 07:33 AM
