Fibrafuse - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-28-2013, 11:41 AM   #1
Rewards Points: 5,978
Fibrafuse
Not to be confused with Fibra tape. I just googled Lowe's drywall tape and see they are carrying the new fibrafuse paperless drywall tape. To all the drywall guys out there try this stuff it is great. I don't want to say to much till I hear what you think, but this stuff makes taping a lot easier. And if you need to skim a rough wall it comes in rolls 36" wide. Plus it can be used in corners and on your angles, And as the name implies it is totally paperless. On Drywall talk a lot of the big companies are going from paper tape to only this stuff. Let me know what you think.
ToolSeeker is online now   Reply With Quote
Old 03-28-2013, 02:23 PM   #2
I'll be done drywalling my basement soon so I'm looking forward to this answer as I may want to try this stuff out.
bova80 is offline   Reply With Quote
Old 03-28-2013, 04:04 PM   #3
I really don't want to say much about it till a few try it. It's a fairly new product and was kind of hard to find that's why most haven't heard of it.
Old 03-28-2013, 06:29 PM   #4
Rewards Points: 512
i seen it come out a while ago and ive been waiting for the local stores to start carrying it probably wont be here for a while. from different reviews online is that guys really like it but on inside corners you can easily cut it with you knife.
princelake is offline   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
ToolSeeker (03-28-2013)
Old 03-29-2013, 12:51 AM   #5
Rewards Points: 626
Myron Furguson tested it on your tube and it has a few flaws other then that he says it is ok.
Nailbags is offline   Reply With Quote
Old 03-29-2013, 01:08 AM   #6
Rewards Points: 744
Great for flat joints, but tears easily, when doing corners. I hear it will also leave fiberglass splinters in your hands. Other than that, I've read a lot of positive reviews on various drywall formus.
Seattle2k is offline   Reply With Quote
Old 03-29-2013, 06:22 AM   #7
well since I'll be taping soon I ordered it off of lowe's website. I could have got 500ft off amazon with amazon prime for $16, but I opted with 1000ft from lowe's for $16.
Old 03-29-2013, 10:13 AM   #8
Yes there is a small learning curve for in the corners so you don't cut it with your knife. Haven't really had the problem with fiberglass splinters. In my opinion it's worth taking a little bit of time to work with, but you will have to judge that for yourself after you use a roll.
Old 04-09-2013, 12:50 PM   #9
well I unfortunately won't be able to test it. manufacture will only send boxes of 10 to lowe's and since I only ordered 4 I don't meet that criteria and they canceled the order. Oh well, I guess paper tape it is.
Old 04-09-2013, 08:19 PM   #10
Yea ain't that a crock. They advertise they have it and then you can't get it.
Old 04-19-2013, 09:39 AM   #11
Rewards Points: 1,476
What makes this better/different than other types of tape? What are the claimed benefits of using it?
EDIT: Checked HD's site.
  • Fibafuse is porous allowing the joint compound to become part of the tape for a stonger bond
  • Fibafuse is mold resistant scoring a perfect 10 rating on ASTM D3273 mold test
  • Fibafuse crack strength is 76 percent stronger than paper tape
  • Fibafuse is 62 percent lighter than paper tape
mikegp is offline   Reply With Quote
The Following User Says Thank You to mikegp For This Useful Post:
ToolSeeker (04-19-2013)
