Fiberglass Tub Surround - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-10-2014, 07:15 AM   #1
Rewards Points: 36
fiberglass tub surround
First time having to deal with this, but my customer has a fiberglass tub surround that the flange screws into the studs. I mentioned furring out the wall and he got the look on his face that he tasted butt. I read somewhere that mixing up some durabond and bedding it into the blue board and filling in the flange then flat taping is the way to go.
Would this work?
onebaddodge06 is offline   Reply With Quote
Old 10-10-2014, 07:30 AM   #2
Rewards Points: 5,974
If i'm understanding this correctly no it won't work. There is to much flex in a fiberglass tub. It will continually crack.
The Following User Says Thank You to ToolSeeker For This Useful Post:
onebaddodge06 (10-10-2014)
Old 10-10-2014, 07:36 AM   #3
Rewards Points: 13,748
#1 Never should be using screws to attach it to the studs.
You use galvanized roof nails, that way there flush with the flange not protruding.
I always use lattes to shim out the studs or there's going to be a hump.
Old 10-10-2014, 08:34 PM   #4
Rewards Points: 36
Bummer. I had hoped durabond to fill the gap and flat tape would work. First surround I've done that doesn't glue to a backer board.
Old 10-10-2014, 09:29 PM   #5
There is no tape used at flanges!
Only need caulking where the drywall meets the enclosure.
A nail on is a far better enclosure, there far thicker.
Old 10-10-2014, 11:40 PM   #6
Rewards Points: 36
I'm referring to the flange on the fiberglass surround in regards to where it meets the drywall and whether to fur the drywall out with shims or fill the gap with a hot mud. And yes I wish the homeowner wouldn't of used the method he did with this tub.
Old 10-11-2014, 08:21 AM   #7
We know what your talking about and have done lots of them.
The type of enclosure he chose is far better, longer lasting, better looking if done right then a cheap stick on.
No way do you want a nonflexible material in contact with the enclosure, it's just going to crack.
Any I've done there was instructions in or on the box and on line explaining all the details.
Old 10-11-2014, 09:41 AM   #8
Rewards Points: 36
Thanks for your input Joe. I'll just get some furring shims behind the studs. I want it done right and not cobbled. Last thing I want is to go back to this guy's house for repairs.
Old 10-11-2014, 11:41 AM   #9
Rewards Points: 454
You will have a better finish if you flat tape against the tube instead of just caulking it
scottktmrider is offline   Reply With Quote
Old 10-11-2014, 12:02 PM   #10
Plumber
TheEplumber's Avatar
Rewards Points: 682
What I see on new construction pretty much as you describe. Fiberglass unit is screwed to the studs, drywall is brought up to the flange and then flat taped with hot mud.
How will you address door/window jambs with furring strips?
Old 10-11-2014, 12:48 PM   #11
Rewards Points: 36
No windows to worry about, and furring the studs won't cause issues with the door, although whoever does the door trim would be very angry since it would change the wall dimensions where the finish trim butts against the wall seam.
I'm starting to wonder if hot mud and flat taping the gap is the way to go. Durabond sounds indestructible if done correctly.
Old 10-11-2014, 01:05 PM   #12
Rewards Points: 454
You won't fur the whole wall out, just tapper it down from the tub flange
The Following User Says Thank You to scottktmrider For This Useful Post:
onebaddodge06 (10-11-2014)
Old 10-11-2014, 02:38 PM   #13
Rewards Points: 36
This sounds like an excellent idea. Really furring .25 won't be all that noticeable of a taper. This guy's framing job is out .75 in a matter of a 30 feet span
Old 10-11-2014, 03:59 PM   #14
Rewards Points: 454
I usually put like 1/4 to 3/8 next to tube than 1/8 on the next stud
I like to use roofing shingles put like 3 streeps next to tub than go out a little than put 2 and so on
Fiberglass Tub Surround mciccone Kitchen & Bath Remodeling 3 08-06-2013 06:47 PM
Removal of fiberglass surround tub sunshin49 Kitchen & Bath Remodeling 2 07-22-2012 05:03 PM
Bathtub fiberglass surround schraggyj Tiling, ceramics, marble 2 08-21-2011 07:15 PM
Tile shower surround above fiberglass shower Gregghea Tiling, ceramics, marble 3 01-28-2011 07:39 AM
Shower door install in unplumb fiberglass surround screenporch21 Building & Construction 1 11-24-2008 02:36 PM
