Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 03-20-2010, 04:26 PM   #1
Fiberglass drywall tape on ceiling
I had my basement finished and ceiling drywalled. My builder used fiberglass tape on drywall joints on the ceiling. Someone told me that it could crack...is this the case? Thanks
lgallo is offline   Reply With Quote
Old 03-21-2010, 11:05 AM   #2
Drywall contractor
It COULD, but then again, paper tape could too, under certain conditions. It has been my experience that fiberglass is more likely to crack, but improper installation can often be the issue. The most important thing to remember with fiberglass is that setting type compound be used on at least the first coat. I have repaired a lot of cracks that were taped with fiberglass tape. Most were finished with regular ready mix mud. The only thing I use it for is minor repairs where I am looking for a finished patch in one trip.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 10:50 AM
Framing for Drywall Ceiling Wino Building & Construction 1 01-13-2010 03:05 PM
Plaster ceiling and drywall desrtrat Drywall & Plaster 13 10-08-2008 08:20 AM
Horizontal drywall w/ dropped ceiling ClnlBrahm Drywall & Plaster 2 09-02-2008 01:38 AM
Drywall Mudding - Tape Lifting Drywall_Dummy Building & Construction 5 09-06-2005 12:53 PM
