-   -   A few questions on skim coating, matching drywall texture, and corners (http://www.diychatroom.com/f101/few-questions-skim-coating-matching-drywall-texture-corners-58233/)
Scott99999 11-30-2009 10:13 PM
Hello,
I've been remodeling a wallpaper-covered bathroom and laundry room.
- The laundry room had wallpaper over drywall. I stripped with Dif, sealed with Gardz, and I've skim-coated this room with Durabond 90. Sanding Durabond is a pain, but the walls are pretty solid now. I'm going to Gardz next, then paint with Aura Bath paint when done.
- The bathroom had some flat paint, some of which was chipped when the wallpaper was pulled off. The wallpaper came off easy, but I've done some patching in this room of damaged drywall after the vanity was ripped out and some old water damage was relaced. I sealed the chipped paint with Gardz and skim-coated the chipped areas. I also patched the various holes. (Sorry - a total drywall replacement isn't an option for reasons too long to list).
QUESTION #1: My flat walls look good in the laundry room, but my corners look like hell (the original corners weren't great). What's the best way to get nice corners? Scrape or cut the originals and start fresh? Better compound technique? Special tool? Sanding?
QUESTION #2: The drywall and paint in the bathroom have a very light texture to them - small bumps. The areas that I've skim-coated or patched, of course, are perfectly smooth. Will the difference in texture show through the Gardz and Aura? Other than skim-coating the entire room :(, how do I minimize the differences in texture? Will the paint naturally create a little texture? Will a roller create texture? Can I skim coat over existing paint? Or do I need to treat or sand the paint first?
THANK YOU!
chrisn 12-01-2009 03:38 AM
#1 What I do is ( this is going to sound strange) using easy sand( not durabond) is get a gob on my finger and run it up and down the wavey corners, sand down the edges, done.
#2 A good nap 1/2 in or 3/4 will certainly create some texture, will it do what you want? maybe, probably
Kevin M. 12-01-2009 06:49 PM
If you plan to use a satin finish in the bathroom it will tend to show the discrepancy in your walls. The lower the sheen the better it will cover. I've had success thinning joint compound to a thick paint texture and rolling over the patch areas. You need a tight nap roller to make it work. Follow that with a spot prime on the patch areas with a thicker nap roller. Subsequent primer and finish coats are best applied with 1/2 or 3/4 inch lambs wool covers. The lambs wool leaves a nice stipple for blending wall areas.
Avoid any type of cheap synthetic roller cover. We call those "corn cobs" in my neck of the woods. :)
Good luck!
tpolk 12-01-2009 07:17 PM
you can rent a hopper and spray gun that will spray a light texture similar to what it sounds like you have. A mix of water and premixed dryall compound goes in hopper and is sprayed on walls the more you spray the more pronounced the effect, called orange peel texture here in Va. you could go over the whole room this way covering your repairs. I would suggest talking to a drywal/texture person for mix requirements or they may be able to help at rental place. this is not a popcorn texture.
chrisn 12-02-2009 02:45 AM
Where is that neck?, corncobs,I have never heard, good one though:)
Kevin M. 12-06-2009 10:52 PM
Nebraska, the Cornhusker Sate.
user1007 12-07-2009 02:40 AM
There are a number of light textured additives you can put directly in the primer. Matching texture is tricky though so experiment. Texture, thinned compound, and stippling it on with something like a wallpaper brush sometimes works.
An inside drywall corner finishing tool might come in handy but I usually do it the way Chris does.
chrisn 12-07-2009 05:20 AM
Really? I thought I was the only person in the world that did that,glad to know I am not alone.:)
user1007 12-07-2009 10:26 PM
It is may fave caulk finishing tool too! And it is always on site and "handy" and I don't have to look for it! I've even been known to use the extended middle one when a client puts me in a certain mood but I cannot guarantee results like I can with the index finger. :laughing:
chrisn 12-08-2009 04:17 AM
I couldn't agree more:thumbsup:
