Feathering Drywall To Door Frame - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-10-2013, 04:25 PM   #1
Feathering drywall to door frame
I recently removed paneling from a room and replaced it with drywall. In this room there is a sliding glass door with a metal frame to my outside portch. Because the drywall is thicker than my paneling was the wood molding that I have around the frame of the glass door is not lining up with the metal frame. About a 1/4 inch gap. I am not sure if I can feather the drywall in so that the mold lines up with the metal frame. If so can anyone give me some advice on how to do this.
dmar is offline   Reply With Quote
Old 10-10-2013, 05:09 PM   #2
Rewards Points: 5,974
If I'm understanding his right (maybe not) you can put corner bead on and mud it.
Old 10-10-2013, 05:46 PM   #3
Rewards Points: 12,808
Post a picture would be a big help.
Old 10-11-2013, 09:57 AM   #4
AHH, SPANS!!!
Rewards Points: 1,166
you will need to add a jamb extension 1/4" to bring the plane of the jamb in line with the face/plane of the drywall ( backside of trim). then your trim will sit against drywall and jamb. might need to glue extension because it is a metal jamb/frame or pre attach extension to backside of trim before hand...
hand drive is offline   Reply With Quote
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 08:08 AM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Repair drywall paper before laying tile? amybeth25 Remodeling 4 08-29-2010 06:49 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
