Fasteners For 1/2" Plaster Over Block - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-05-2012, 05:25 PM   #1
jkk
Rewards Points: 233
Fasteners for 1/2" plaster over block
Need to hang curtain rods on walls that are 1/2" - 5/8" plaster over concrete block.
What kind of fastener will work? Thanks.
jkk is offline   Reply With Quote
Old 10-05-2012, 06:12 PM   #2
Rewards Points: 13,740
No insulation? No straping on the wall?
Use a Tap-Con screw. Going to need a hammer drill and a masonry bit.
Old 10-05-2012, 06:22 PM   #3
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
They are curtain rods,use plastic anchors like you would in sheetrock.
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
ToolSeeker (10-06-2012)
Concrete Plaster coat Mix ratio needed, for brick interior wall. Spud Concrete, Stone & Masonry 6 07-08-2012 01:55 PM
Drywall over 4" block wall base JustADoc Drywall & Plaster 7 09-12-2011 10:47 PM
Vertical Rebar Layout in Block Wall Footing 99altrade Building & Construction 6 08-12-2011 09:32 PM
plaster over CMU block woodmeistro Drywall & Plaster 9 08-10-2011 05:57 PM
Bathroom Remodel - Resurfacing Plaster over Concrete Block itcanadian Remodeling 2 05-30-2011 10:10 AM
