Faking Venetian Plaster / Knockdown (Sort Of) - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-14-2011, 09:48 AM   #1
Former Contractor
PTP WX's Avatar
Faking Venetian Plaster / Knockdown (Sort of)
Hello professionals! I was a drywall contractor (commercial) from 1988-1993 to put myself through college, since then have only done remodeling stuff on my own. So I am a bit out of style and practice, but I do have almost every drywall tool still.
My house was built in 1985, we bought it in 2004. My wife and I absolutely HATE the orange peel texture that is in portions of our house. Other parts are a knockdown texture, almost to a venetian plaster effect. It is really nice, and I want to mimic that effect through the upstairs 2 bedrooms, hallway and staircase. I attempted to mimic the texture in a small upstairs bathroom by hand. It worked pretty well but took forever! I had skim coated with slightly thinned mud on a 12" knife, then did X patterns with a 6" knife, then ran a 24" knockdown over it. Looks fairly close but the mud on the wall was a little too thick.
I am thinking that the last contractor didn't use that method, because the house isn't worth that much, it didn't look exactly the same, and it would take WAY too long. Now I figure they sprayed texture fairly thick then ran a knockdown knife over it.
So my question is how modern professionals would create that look? I have access to a small texture gun & compressor if I need it. Thank you!
PTP WX is offline   Reply With Quote
Old 01-15-2011, 09:25 AM   #2
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 906
If you could post a picture of the texture your trying to duplicate, that would help us.
Sir MixAlot is offline   Reply With Quote
Old 01-15-2011, 05:54 PM   #3
Thats probably what it is. A heavy spray on texture that was knockdown with a knife.
Practice patterns and mud mixes in the garage. You don't knockdown until the mud has started to set up a bit. Otherwise it will just want to flatten out, and will be hard to work.
The mud for spray is thicker of course than an orange peel mix, and the air on the compressor is low to allow a larger pattern of mud.
redmanblackdog is offline   Reply With Quote
Old 01-15-2011, 11:27 PM   #4
Former Contractor
PTP WX's Avatar
I have Thursday and Friday blocked out for texture and primer.
I'll post some pictures Monday or Tuesday.
Thank you.
Patrick
Old 01-18-2011, 11:02 AM   #5
Former Contractor
PTP WX's Avatar
Faking Venetian Plaster / Knockdown (Sort of)-p1030165.jpg
This is the texture I am trying to recreate!
Faking Venetian Plaster / Knockdown (Sort of)-p1030167.jpg
Here is the Orange Peel...
Faking Venetian Plaster / Knockdown (Sort of)-p1030169.jpg
Here is the bathroom that I did by hand.
Any advise? Knockdown knife on a thick texture spray?
Thanks,
Patrick.
Faking Venetian Plaster / Knockdown (Sort of)-p1030170.jpg
Old 01-18-2011, 02:25 PM   #6
If the spray is not quite heavey enough.
You can get a similar effect that will be heavier by taking the mud straight out of the box, and using a hawk and trowel(hawk, being a handle perpendicular to the 12"x12" flat surface you put the mud on). Put the mud on the hawk and flatten it out. Then use the trowel to make stipples in the mud by putting your trowel on it and pulling it back away. It will also stipple on the trowel and you can use it that way to touching in the edges. Then touch the stipples to the surfaces. Work that way for 20 to 30 minutes and then knock it down with a trowel.
Old 01-26-2011, 04:59 PM   #7
Drywall Texture Pro in Fl
stoner529's Avatar
Rewards Points: 154
I agree. there is a slight possiblity that it was sprayed on with thinner material so it grouped together easier and then was let to set up for a bit, and then flattened.
how to remove popcorn
stoner529 is offline   Reply With Quote
Venetian Plaster FYI Plaster Ayn Painting 10 06-30-2010 11:26 PM
Venetian Plaster Fireplace Plaster Ayn Painting 0 01-19-2010 10:42 AM
Venetian Plaster Plaster Ayn Painting 10 12-01-2009 06:40 PM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 12:10 PM
venetian plaster farrington135 Painting 1 01-02-2006 05:44 PM
