Is The *Face* Of Drywall As Just The Same Hardness - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-01-2012, 07:41 AM   #1
Rewards Points: 296
Is the *Face* of Drywall as just the same hardness
I've always been under the presumption that 5/8 Firecode Sheetrock has a *harder* top edge surface then let's say 1/2 Mold. Well, this was based on the last time I hung a tonnage of sheetrock on a large remodel.
Interesting enough, as I need a thin sheetrock to finish off the edge, and the 3/8 I saw was just as *tough* on the surface to dents as the 5/8" I know.
I still need head down to the bldg. supply to get the 1/4" I need but I'd be curious to know if sheetrock these days are just as *hard* - irrelevant of thickness
mobiledynamics is offline   Reply With Quote
Old 03-02-2012, 04:59 PM   #2
Drywall contractor
Rewards Points: 1,070
Hit the various thicknesses of board with a blunt object (not you fist, especially on the 5/8") and you'll see they are NOT all created "equal".....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-02-2012, 11:54 PM   #3
Registered User
Rewards Points: 526
Impact Resistance (typical)
(ASTM E 695)
(Using 50 lb (22.7 kg) leather bag, one test per specimen. Impact point located at midpoint between studs. Impact
Resistance - Drop height at penetration through impacted membrane.)
Thickness Board Tested on 2x4 (nominal) wood studs
16" (400mm) o.c.
Type
in. (mm)
1/2 (12.7) regular 12"
1/2 (12.7) type X 24"
5/8 (15.9) type X 30"
From: https://docs.google.com/viewer?a=v&q...U1o3kfoOlKl-7Q
Gary
Old 03-03-2012, 12:31 AM   #4
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I think he means hardness like sticking your fingernail in it.
All the same.
titanoman is offline   Reply With Quote
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 07:08 AM
Drywall Dust Question izzyant88 Building & Construction 2 10-28-2011 09:32 PM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 08:15 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
