Expanded Mesh Cornerbead OK For Drywall? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-19-2013, 02:07 AM   #1
Expanded mesh cornerbead OK for drywall?
Mfrs say it's a veneer plaster product, but is there any reason not to use with drywall and Durabond 90?
thatbobguy is offline   Reply With Quote
Old 03-19-2013, 06:57 AM   #2
Rewards Points: 13,750
Why would you want to?
If your doing drywall just use a reguler steel drywall corner.
Old 03-19-2013, 02:04 PM   #3
Rewards Points: 626
I would use a regular corner bead. and why do you want to use that type in the first place?
Nailbags is offline   Reply With Quote
Old 03-20-2013, 01:28 AM   #4
Reason I asked, is that USG makes an #800 mesh corner that I know is for drywall (because USG says so), and is staple attached, but the ones I've seen locally are from Clark-Dietrich or Marino-ware and are spec'd as veneer plaster products.
Just wondered if they're all the same thing.
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 49 05-23-2013 01:04 PM
how to make a cylindrical box out of mesh anorphirith Building & Construction 2 02-25-2013 12:20 AM
Wire mesh for vents rather big? daluu Building & Construction 1 12-04-2012 07:09 PM
Welded Wire Mesh & Fiber Mesh Jim Anton Concrete, Stone & Masonry 4 05-01-2012 04:22 AM
Al. mesh filters lottaair HVAC 1 09-13-2010 05:34 PM
