Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 09-30-2012, 02:47 PM   #1
Existing drywall two inches above the floor
Hi,
I am redoing a closet and getting ready to put a new floor in. After I removed the baseboard I realized the drywall is about 2" from the subfloor. The previous owner had put some scrap board behind the base (see pic below) to have something to nail into but did not tape it so it was a mess. I've cleaned it out (see pic below) but not sure what to do now. Should I patch in new drywall, put a board around, something else? Any guidance would be very appreciated.
Thanks!
Melissa
mantissa is offline   Reply With Quote
Old 09-30-2012, 02:54 PM   #2
I bet if you measure from the floor to the ceiling you will find it was more then 8' tall. I'd clen off that area so there was no humps and just tape and mud it. Your just trying to stop air leaks. One coat should do it, then sand it flat.
Old 09-30-2012, 06:07 PM   #3
If baseboard covers it just rip the right thickness of plywood (1/2" or 5/8" often) and put it in gap. Then baseboard over it.
mae-ling is online now   Reply With Quote
Old 09-30-2012, 06:08 PM   #4
joecaption you are right on the height - just measured and it's 8' 2". Guess they figured why tape/mud if you can't see it.
mae-ling, also a good point. The baseboard does cover it. I wonder if there would be any downside with a wood fill-in.
Thanks!!
Old 10-01-2012, 05:02 AM   #5
paper hanger and painter
chrisn's Avatar
Put the base board back up and forget about it, it's done. I am sure you have more pressing issues that you could worry about
Old 10-01-2012, 09:40 AM   #6
You need to put at least a small block of plywood or something along to bottom just keep your base from tilting back at the bottom.
Old 10-01-2012, 09:42 AM   #7
inside wall =just put the base board back on. outside wall = caulk it then put the base board back on.
if you are going to paint, paint first, but after the caulk.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 10-01-2012, 09:50 AM   #8
I agree. If it's in interior wall, just put the base back up. It won't be a problem. If it is an exterior wall, seal it up so you have no air leaking through then put the base back up.
NHtransplant is offline   Reply With Quote
Old 10-01-2012, 07:25 PM   #9
Thanks for all the replies/advice. I'll let you all know what I end up doing and how it goes
Airtight Drywall Seams Around Existing Duct? EricCJacobson Drywall & Plaster 4 07-07-2011 11:14 PM
Drywall frame without connecting to the floor and ceiling ykykyk Carpentry 4 05-09-2011 05:08 PM
Insulating an existing floor over a concrete slab rbo Flooring 1 12-06-2010 06:41 AM
New Floor Drain in Existing Concrete Floor JPWMU Plumbing 3 04-21-2010 06:51 AM
Second floor addition over existing 1st floor. handball Building & Construction 1 02-10-2009 02:08 PM
