Estimate Drywall ?? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-14-2013, 01:07 PM   #1
Estimate Drywall ??
If you have a 2 story building with 10 ft ceilings, 54,000 sq ft which will be used for hospice rooms, etc, how would you calculate drywall, just an estimate. 4.6 x sq ft ? No plans to look at so I do not have size of rooms, ceiling height will be 10 ft thru out, any ideas?
"don't bend over in the garden, granny, them taters got eyes"
newfie49 is offline   Reply With Quote
Old 12-14-2013, 01:52 PM   #2
Rewards Points: 13,250
length X height X number of walls, divided X the number of sq. ft. in the panels.
May want to check with your local building inspector you may have to use all 5/8 on walls and ceilings, have wires in conduit, hospital grade outlets, party walls between rooms, handicapped door knobs for that type housing.
I know your going to need fire blocking in the walls with ceilings that high.
Old 12-14-2013, 06:06 PM   #3
Rewards Points: 5,974
Use 10' sheets of drywall vertical. You had better really check your codes for your area. I do a lot of work for hospice and from your post it sounds like you will fall under the same codes as a hospital. And they can be really tough.
Old 12-14-2013, 06:15 PM   #4
Someone correct me if I'm wrong but 10' sheets are 40sf divided into 54,000sf=1350 sheets.
Old 12-14-2013, 06:55 PM   #5
54000 would be the sq. footage of the rooms, not just the walls and ceilings.
ToolSeeker (12-14-2013)
Old 12-14-2013, 08:41 PM   #6
Hope it's not just the footprint of the building.
Anyway you look at it a huge job, and 10' ceilings make it a lot worse
Old 12-15-2013, 12:42 PM   #7
retired union carpenter
Send a message via Yahoo to coupe
you really need blueprints and spec book! closets and baths need drywall on both sides, some walls may require 2 or 3 layers? elevator shaft probably core board 1" thick?
I've done seveal hospitals, never one with drywall cielings except in operating rooms and xray rooms which need lead backed board
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 12-16-2013, 02:56 AM   #8
Rewards Points: 4,792
If you don't know the hallway and room dimensions, you can't possibly estimate this. It's based almost entirely on the number of rooms and sizes, not square footage of the space.
jeffnc is offline   Reply With Quote
Old 12-18-2013, 07:52 AM   #9
Mold!! Let's kill it!
Rewards Points: 2,012
Not to mention duct shafts, pipe chases and oxygen storage rooms that all require rated walls and a lot of hospital based specs are now calling for mold resistant board. You'd better read the specs very carefully. Know where the rated walls are and what is code required for construction.
Drywall Estimate - ATLANTA eddle6389 Remodeling 7 02-01-2012 10:07 PM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 02:08 PM
Drywall ceiling above bathtub/shower larabiec Drywall & Plaster 3 06-26-2011 02:23 PM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 03:30 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
