#1 |
Ensuite Bathroom Rebuild - what type of drywall?
Hi Everyone,
I am rebuilding an ensuite bathroom. Today I re-insulated the exterior walls and applied a vapour barrier complete with tuck tape and acoustic caulking. From what I understand it is advisable to get some type of interior wall up ASAP. The bathroom is going to have a stand up shower (no tile, acrylic walls and base with glass doors), toilet and sink, and will be used by adults. That said I don't expect there to be excess moisture but I'm still going to install an exhaust fan. The ceiling is already drywalled with the bluish/greenish drywall from the original construction, but I just want to make sure that this is acceptable for the rest of the walls. If not, what do I need to install, and are there any specific installation instructions I need to follow? Thanks in advance |
#2 | |
Masters in Drywall
Ensuite Bathroom Rebuild - what type of drywall?Quote:
There are building codes against using "green board" on exterior bathroom wall because it traps moisture between the vapor barriers and creates mold. Unless there is a new sheetrock type I'm not aware of for your exterior bathroom walls, I would go with the regular sheetrock. Last edited by MnDrywallRanger; 03-20-2011 at 07:35 AM. |
#3 |
use the green board around sinks and tubs. regular for the rest of the walls you will be fine hang across the studs you can screw and glue or nail the rule of thumb is two nails for every screw in the field if screwing three screws in field per stud
| Display Modes | |
| Can I install Kerdi over primed drywall in a basement bathroom? | Mechelle | Tiling, ceramics, marble | 13 | 04-22-2012 11:50 AM |
| Bathroom Drywall | jeepwillies | Drywall & Plaster | 11 | 05-03-2011 01:04 PM |
| Bathroom drywall | Patti B. | Drywall & Plaster | 3 | 02-21-2011 05:01 PM |
| Bathroom floor - Kerdi Band for Ditra / drywall joint? | Airgibson | Flooring | 12 | 08-04-2010 10:33 PM |
| Type of drywall for wine cellar... | Goliath | Building & Construction | 3 | 02-03-2006 12:11 AM |
