Electric Box In A Tapered Edge Joint - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-21-2010, 09:00 AM   #1
Electric box in a tapered edge joint
I have a switch box that falls in the middle of a horizontal tapered edge seam. I was thinking of covering the box with masking tape and then just taping and mudding over it like it wasn't there. After sanding I would just cut it out of the finished wall. Is there a better approach?
Thanks,
Brian
briank is offline   Reply With Quote
Old 06-21-2010, 09:09 AM   #2
Handyman
Rewards Points: 512
Yep, that'll work. I usually just mud starting at the box and moving away from it without tape. If there is any on the box when I'm done I just chip it off.
canadaclub is offline   Reply With Quote
Old 06-21-2010, 05:14 PM   #3
Old School
Willie T's Avatar
I often do just what you are anticipating. It works quite well.
Willie T
Tags
taping
small baseboard against tapered edge rtoni Drywall & Plaster 4 05-17-2010 10:07 AM
Mitre or butt joint for laminate countertops with roundover edge? tigereye Kitchen & Bath Remodeling 1 02-04-2010 11:33 AM
butt end butts up against tapered edge... Jeremy Hillary Boob, PhD Drywall & Plaster 4 01-25-2010 09:51 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
Drywall - butt edge to tapered edge Richo Drywall & Plaster 5 04-20-2009 10:33 AM
