-   -   Electric box in a tapered edge joint (http://www.diychatroom.com/f101/electric-box-tapered-edge-joint-74245/)
briank 06-21-2010 09:00 AM
I have a switch box that falls in the middle of a horizontal tapered edge seam. I was thinking of covering the box with masking tape and then just taping and mudding over it like it wasn't there. After sanding I would just cut it out of the finished wall. Is there a better approach?
Thanks,
Brian
canadaclub 06-21-2010 09:09 AM
Yep, that'll work. I usually just mud starting at the box and moving away from it without tape. If there is any on the box when I'm done I just chip it off.
Willie T 06-21-2010 05:14 PM
I often do just what you are anticipating. It works quite well.
