Easy Way Or Hard Way...or Can Hard Way Be Easy Way? - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-06-2011, 03:52 PM   #16
automated tool pro
Rewards Points: 152
5/8th rock is great for both sound and hiding old framing issues. As for reselling the box.....not likely in todays economy
drywallfinisher is offline   Reply With Quote
Old 07-07-2011, 06:47 AM   #17
Rewards Points: 320
Thanks...I did my best to estimate the amount i'll need and any left over I can just save and use for a room upstairs i'll need to refinish. I'm going to get 100 sheets of 5/8" 4x12. The guy at the store said they only have the heavier mud in the cans and that i will need 1 bucket for every 10 sheets and the same for rolls of tape. Does this sound about right? Should I go somewhere else to be able to get the two different kinds of mud?
autx790 is offline   Reply With Quote
Old 07-07-2011, 04:37 PM   #18
automated tool pro
Rewards Points: 152
250 ft roll paper tape for every 25 boards. as a rule take your floor footage''''example 1300sq ft and divide that by ten to get your board count....130 boards
keep in mind you also have ten ft ceilings. one extra board for every 24 ft of wall.
you want the light weight mud by the way....you will be cussing yourself later if you dont get it....sanding sucks
Old 10-21-2011, 10:52 AM   #19
Rewards Points: 320
Well I finally got all the drywall hung (88 sheets of 12ft boards). I'm trying to decide if it's worth it to hire out for the finishing. I'm getting everthing from $9/board to $0.57/sqft. I dont really have $2500 to spend on labor right now for something I think I could do. Though it would be nice and much faster to have someone else do it. My question now is, I have a lot of joints where there is a tapered edge butting up to a cut piece. Do the flat boxes still work well for a joint like this, or are they made to only work on like-edges?
Old 10-22-2011, 02:23 PM   #20
automated tool pro
Rewards Points: 152
$9 dollars a board is not $2500. that price sounds about right for a professional finisher.
To answer your question though...no. Only use boxes on your factory to factory seems. Split your joints like that like you would a butt joint. If you use a box you will leave too much mud and mounding will occur.
https://www.facebook.com/drywall.Asheville
Old 10-23-2011, 06:36 PM   #21
Rewards Points: 320
great, thanks for the info! Sorry, I didn't equate the $9/board to sq ft pricing. the $2500 is about what I was getting but someone had said he'd do $9/board which was a lot cheaper. Doesn't matter much though, once he saw the job, that price didn't stick. Which I could understand. I'm still torn trying to figure out if i should tackle this my self. I know I could do it, but I'm wondering if it might take a lot longer than I think. Mostly cause of the exposed beams in one room, 10ft ceilings, and a 28ft tall stair well. It would be real nice to have it painted before thanksgiving.
Old 10-23-2011, 08:58 PM   #22
automated tool pro
Rewards Points: 152
28 ft stairwell...is still a stairwell. 4 years ago as a rule I always priced jobs between $8's for 8ft ceilings $9's for 9ft and $10 for 10ft. even with a 28ft stairwell that price wouldnt change because most houses with 10ft ceilings have stairwells 18ft or higher. With the way the economy is going Ive been finishing anything over 80boards at $9's as long as I can reach the ceilings off stilts....and that typically includes a high "great" room. Too bad you're not a little closer, I'd love an 88 board job right now. I've resorted to working hourly doing restoration work. I run ads continuosly through craigslist, angieslist, and facebook and am in the #1 spot on google for Asheville drywall.
I think a lot of times people just dont know who to call when looking for drywall help. Most think the drywall contractor...... when they should be thinking the drywall sub contractor IE; the guy that actually does the work. Then you get it going in the other direction where the guy that thinks he's a drywall contractor and just has familiarity with the trade and over prices his self right out of a job. Whoever gave you the price by the ft. is still living in the housing boom dream state. lol.. Reality says the cost of labor adjust to whatever the labor market pays....if the drywall tradesman cant do it for the money that is consumer friendly, then he really didnt need the job anyway because he doesnt see any value in it. A resentful drywall finisher cant ruin a job...That's why whenever I look at a job I think of the most efficient way to get it while at the same time reminding myself its just another drywall job. eventually it will be conquered and ready to paint.
what to do: assuming you live near a median size city, go to craigslist and run an ad in their help wanted section stating... wanted drywall finishing sub with insurance ..only reply to the english speaking callers and ask to see their last job. If the caller cant give you a recent job to look over he probably isnt legitimate or a very good finisher. The ones that can, tell them you want a per board price and ask what they charge per board for $10 ceilings throughout with the stairwell. Most professional finishing subs can tell you over the phone roughly what t5he job would cost. me myself depending on the way the job was hung $10 per board. good luck
Hardwood Floors - how hard it is? non-voc products? irishgem@ymail. Flooring 10 06-26-2011 05:52 PM
Couple of easy (I think) questions... tigereye Electrical 2 03-01-2010 10:33 PM
An easy question for your guys which is hard for me~ pls help~~ keifoo Electrical 9 10-05-2009 10:58 AM
How hard to replace window screens? TomBrooklyn Building & Construction 4 01-04-2009 09:03 AM
replacing brass shower fixtures; how hard? tarheelblue Plumbing 6 01-26-2008 08:18 PM
