Easy Sand Setting Vs. Green Bucket - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-31-2011, 08:02 PM   #1
Rewards Points: 290
Easy Sand Setting vs. Green Bucket
What JC is harder when dry - easy sand setting JC versus green bucket.
I plan to use Green bucket for the finish coat but durabond brown bag is not available. Alot of the supply houses carry the ES setting as well as the big box stores.
For the taping.....which one is the harder finish, ES setting or green bucket.
Drying times is a whole nuther discussion...
mobiledynamics is offline   Reply With Quote
Old 11-02-2011, 05:21 PM   #2
self help
green will be a bit harder it has glue in it... Im taping a hallway and being a beginner I will be making a few batches of 90 for my retaping, then skimming the wall with easy sand
bigjon is offline   Reply With Quote
Old 11-02-2011, 05:23 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Why are you guys sanding anything?
The Following User Says Thank You to Bud Cline For This Useful Post:
Willie T (11-02-2011)
Old 11-02-2011, 06:48 PM   #4
Rewards Points: 290
I had to hunt for this stuff as a couple of the bigger supply houses did not even carry durabond vs. es setting compound....hell, the counter guys think it's the same stuff, just *better* as it's sandable.
Found it but also ended up paying $4 more per bag than what I thought it should be at......
Don't use Easysand IMO. It's really soft. Do 2 coats of durabond, maybe a 3rd depending on how wide you go, and then finish it off with green bucket. It will be a much harder finish overall...
Old 11-03-2011, 06:16 AM   #5
self help
cause this ain't my day job...
The Following User Says Thank You to bigjon For This Useful Post:
oh'mike (11-03-2011)
easy plumb shower tray - small gaps at edge wilson.campbell Plumbing 1 06-10-2011 04:28 PM
Is there an easy section to cut out one piece of a baseboard? abefroman Remodeling 2 07-28-2010 02:00 PM
Couple of easy (I think) questions... tigereye Electrical 2 03-01-2010 10:33 PM
two easy bathroom drywall questions amakarevic Building & Construction 2 04-30-2008 09:17 AM
