Easy Question...taping Corner Beads? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-03-2010, 03:20 PM   #1
Rewards Points: 262
Easy question...taping corner beads?
I know somebody who is doing some drywall work on the side, and he mentioned that he spoke with "professional tapers", and they told him to tape the cornerbeads as well as the joints. I hadn't heard that. Is it common, preferred, or just a waste of tape?
tpagel is offline   Reply With Quote
Old 05-03-2010, 08:40 PM   #2
DIY staff
Rewards Points: 7,174
Waste of tape and time---Most likely done by someone who hasn't learned how to fasten the corner bead properly.--Mike--
Old 05-03-2010, 09:37 PM   #3
Rewards Points: 256
well in the past before they used tape on beads they commonly used a clincher then you should tape the beads - commercial metal studs ... you can tape the beads if you want i use hot mud on the first coat instead.
oldrivers is offline   Reply With Quote
Old 05-07-2010, 08:55 AM   #4
Drywall contractor
Rewards Points: 1,070
I have never taped a corner bead in 35 years.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 05-10-2010, 12:06 AM   #5
Rewards Points: 256
its more for insurance than anything. you can put a bead on 100% perfect but that wont guaruntee the wood behind it wont twist shrink or the bead wont get bumped. the tape might not prevent all cracks but i dont see how it hurts anything its just burried under the mud, i believe taping mud sticks to metal better than light mud .. and light mud sticks to tape better than metal so i can see an advantage to it. but i use hot mud on the first coat just for insurance reasons.
clinching is also a method that lets you attach a bead without putting any nails in the wood. the wood twists shrinks etc pulling on the nail inturn pulling the bead ...
Old 05-10-2010, 06:13 AM   #6
Drywall contractor
A bead with no nails in it is much easier to knock loose (when moving furniture, for example). Bead should be nailed on wood framing. Again, mud-on bead is the best.
Old 05-18-2010, 12:15 PM   #7
Rewards Points: 150
Using metal bead and nails (mfg recommendations) I always mesh tape and hot mud the edges, holding the tape back a little so it doesn't run up on the bead part. This is what is called "best practice", certainly not the standard.
Many of the mud on beads were developed because the above method did improve the ability to resist cracking. Here in CA we have a lot of "seismic events" which makes for more concern in this area.
kgphoto is offline   Reply With Quote
easy question - PVC conduit connection to main panel tpagel Electrical 14 07-17-2009 06:50 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
Easy Heat Pump Question brutis HVAC 6 11-03-2008 10:06 AM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
Easy Drywall Question hohandy Building & Construction 10 12-16-2005 12:18 AM
