Easy Drywall Question.. Where To Cut Drywall When Remodeling?? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-24-2010, 01:20 AM   #1
Rewards Points: 115
Easy Drywall Question.. Where to cut drywall when remodeling??
I have a leak in the basement and need to remove almost the entire wall (drywall) to expose the problems area. So, is it easier to cut the drywall short of the ceiling by maybe a foot, or to just cut along the corner where the wall meets the ceiling??? What would be easier to repair?
RickDel is offline   Reply With Quote
Old 03-24-2010, 03:46 AM   #2
Cutting 1ft short of the ceiling seems like wasted effort. When you put your walls backup, you will need to cut the new sheet of drywall to the right size, and then there is an extra joint to hide. Just cut up to the ceiling, and replace with full sheet drywall.
Are your ceilings 8ft high?
acerunner is offline   Reply With Quote
Old 03-24-2010, 09:21 AM   #3
Rewards Points: 115
Yes, 8' ceilings. (I think I know where you're going with that.... two sheets of 4x8)
I've gotten pretty good at patch work on flat surfaces, but I've never done anything in the corners.
Old 03-24-2010, 11:09 PM   #4
firehawkmph's Avatar
Rewards Points: 1,798
Rick,
kinda like 6 of one, etc. The only reason you might want to cut it short is if you have a textured ceiling that is in good shape and don't want to tape into that. So in that case, cutting it short may be easier as long as you feel comfortable with taping. I do this all the time in kitchens in between the tops and upper cabinets. Usually when removing old tile backsplashes, it's easier to just take the swatch of drywall and all. If you do cut it short, draw yourself a nice line to follow so you don't have to cut some kind of tapered piece to put back in.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 03-25-2010, 04:14 AM   #5
Rewards Points: 115
Thanks Mike...
Old 03-27-2010, 08:12 PM   #6
Military Mom of 4
Snav's Avatar
You can get a small can of ceiling texture and blend in your joint there if it's necessary
Either way you do it you need to consider spacing between the joists. If the spacing between the joists is huge (as is in my house where they didn't measure anything) then you might have to run a 2x4 horizontal - joist to joist - where the edge of the drywall is for some support.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 03-28-2010, 10:21 AM   #7
Drywall contractor
Rewards Points: 1,068
Any time you get into the ceiling angle, you'll have to paint the ceiling also. New texture won't match the color of the old. Just another consideration....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-28-2010, 10:24 AM   #8
Military Mom of 4
Snav's Avatar
Yeah, that's true - whites brown over time.
Drywall Question kerry42 Drywall & Plaster 4 11-13-2009 05:03 PM
Drywall corner question Anne Drywall & Plaster 2 11-13-2009 04:50 PM
Another drywall question Curious Homeown Drywall & Plaster 3 11-09-2009 04:12 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
Easy Drywall Question hohandy Building & Construction 10 12-16-2005 01:18 AM
