Dyrawll Gap With 45 Degree Wall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-23-2013, 11:02 AM   #1
Dyrawll gap with 45 degree wall
I have a wall at 45 degrees to each other. However, the walls do not butt up together and was wondering how to fix this issue? Do I fill it up with Durabond 90 min, tape, then mud again after? If I do this will it crack?
Or is there another way to tackle this?
CasperTron is offline   Reply With Quote
Old 08-23-2013, 03:31 PM   #2
Rewards Points: 6,034
What I would do is cut off some of the inside corner so the gap is not so big. Like a miter doesn't have to be flush but a lot smaller. Just thought how are you going to screw this to the side? Then you could use a corner bead like no-coat which is good for off angles. And I'm not to ask why you would finish a corner like that.
Old 08-26-2013, 09:01 PM   #3
It's quite a difficult task to cut the angles. What about Trim Tex? Would this be a better solution???
Old 08-27-2013, 06:04 AM   #4
What you need to do is go on Trim Tex website they make several beads for off angles. I would guess you will need an over sized bead and they make them.
The Following User Says Thank You to ToolSeeker For This Useful Post:
mae-ling (08-27-2013)
Old 08-27-2013, 09:10 AM   #5
THanks ToolSeeker! I'll do that, I feel more confident with the Trim Tex stuff! Cheers!
The Following User Says Thank You to CasperTron For This Useful Post:
ToolSeeker (08-27-2013)
Old 08-27-2013, 09:50 AM   #6
Haverhill Trade 1965
There is also a standard metal tape, (paper tape with two strips of metal inside. Made for any angle corner inside. Most drywallers around here would fill with durabond and bed the metal tap in it just like any other joint.
Duckweather is offline   Reply With Quote
The Following User Says Thank You to Duckweather For This Useful Post:
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Can I remove this wall? limited60 Remodeling 9 06-05-2012 01:32 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
