Dust/residue After Tape And Compound - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-06-2013, 03:59 PM   #1
Rewards Points: 874
Dust/residue after tape and compound
The guys finished the job today and I noticed that there is some dust left behind on the walls.. I guess from the sanding. The guy said I can take a damp towel and wipe down the walls. I guess he should of done this but whatever ..... My question is should I do this or use something else? Thanks
Joe...I did not say spack$&....
Mstrlucky74 is offline   Reply With Quote
Old 04-06-2013, 04:19 PM   #2
Rewards Points: 512
i have a shop vac with a hepa filter and a soft brush end and i vac the walls. or take a soft bristle broom and brush down towards the floor and i use a paint brush in the top corners. i then sweep lightly or shop vac up the floor then give it a quick mop. then i break out the primer.
princelake is offline   Reply With Quote
Old 04-06-2013, 04:23 PM   #3
Rewards Points: 13,740
Much better.
Brush it off then wipe down with a slighty damp rag to be 100% sure you got it all.
Primers not going to stick to the wall with dust on it.
Old 04-07-2013, 06:09 PM   #4
Rewards Points: 5,974
Drywall dust is very fine so don't be surprised if you need to wipe it down a couple times.
does setting compound need tape? redline9k Drywall & Plaster 8 01-08-2012 01:27 AM
Tape or Joint Compound bigwill Plumbing 4 05-27-2011 08:34 PM
Wrong type of Joint Compound or Tape bigwill Drywall & Plaster 5 05-18-2011 11:30 AM
First time taping - Tape has air under it theedudenator Drywall & Plaster 16 04-21-2010 11:13 PM
tape and float - tape is coming off! samf Remodeling 3 09-29-2006 08:09 AM
