Durock In Shower Alcove - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-04-2013, 08:31 AM   #1
Rewards Points: 660
Durock in Shower Alcove
We are remodeling the basement and adding a bath. The 30" x 60" tub is being built in an alcove along the outer wall. The alcove comes out 34" from the outer wall. Do I bring durock to the edge of the tub and drywall the last 4"? I plan on tiling all the way to the edge. If I am supposed bring durock all the way to the edge, then how do I finish the corner where the durock meets the drywall?
B
Beepster is offline   Reply With Quote
Old 02-04-2013, 08:35 AM   #2
Rewards Points: 13,468
Got a picture or a drawing?
Most people use tile board and bull nosed tile, or even outside corner tiles if it wraps around a corner.
Old 02-04-2013, 08:41 AM   #3
DIY staff
Rewards Points: 7,174
You could fill that gap with drywall if you wish---use a corner bead---it's a dry area so metal or plastic could be used---
Do yourself a favor---check that end for plumb---if it's out of plumb in the least your tiling job will be very frustrating-----
Old 02-04-2013, 09:18 AM   #4
Rewards Points: 660
I am at work so no picture for now. The bathroom is 7' wide and the tub is 5' wide. The alcove comes out 4" beyond the tub and then goes one foot to the outer walls on each side.
Oh, that's what I was thinking I was going to do, drywall the 4" beyond the tub and use a corner bead on the corner. If we use 6" tile (not sure yet) then 2" would be on the durock and 4" on the tile. I have not researched yet, but can you put Redguard on the drywall that will be under the tile or is it strictly for cement board?
Out of plumb? As in what sense? What do I need to make sure is plumb to what?
Thank for the input guys.
B
Old 02-04-2013, 09:57 AM   #5
DIY staff
Red Guard can and should be used on that drywall----
Because your tiles will be perfectly level and plumb---that outside corner better be also---or you caps will need trimming---which always looks like a mistake----
Old 02-04-2013, 11:20 AM   #6
Rewards Points: 660
Gotcha, that corner vertically should be the exact same distance from the outer wall.
B
Old 02-04-2013, 11:28 AM   #7
DIY staff
No---that outside corner need to be PLUMB---use your level---you will start there and make cuts at the back wall---back wall might be off plumb----that's why you start at the 'show' edge--and head to the back wall---
Nailbags (02-05-2013)
Basement bathroom shower remodel NewHomeDIYGuy Kitchen & Bath Remodeling 39 11-26-2013 10:20 AM
Frameless Glass Shower Install lynxpilot Kitchen & Bath Remodeling 12 10-23-2012 11:14 PM
Repairing Botched Shower Tile Step kyann38 Flooring 10 10-23-2012 05:34 PM
Tiled Shower Repair Help, Please Unicornz0 Plumbing 2 09-16-2012 09:22 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
