Durock (CBU) To Drywall Transition HELP - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-16-2009, 01:40 AM   #1
Exclamation
Durock (CBU) to Drywall transition HELP
Hello everyone, and please excuse me because this is my 1st post on this site. I am currently in the middle of my bathroom renovation and I have what may seem like a stupid question. In my shower unit, I have the CBU on all three walls and I need to know the best procedure for transitioning from the CBU to the MR drywall.
Do I FibaTape or paper tape the seem between the two? Do I use traditional joint compound or something else to ensure better water and steam protection? The main concern is the area between the top of the cement board where the tile will stop and the MR drywall that will go form there to the ceiling. Thanks in advance!
Honeydo_MD is offline   Reply With Quote
Old 09-16-2009, 07:16 AM   #2
Do use mesh tape on the joint. Actually, I usually stop the backerboard just below the top of the tile. Then caulk the tile top. That way the joint is covered, and it is generally high enough that moisture is not as big an issue.
Old 09-16-2009, 12:05 PM   #3
Registered User
Termite's Avatar
Just like Just Bill said!
Be CERTAIN that you have solid framing/blocking behind that seam...You don't want the edge of either piece floating out in space between studs.
Old 03-27-2010, 08:07 PM   #4
Military Mom of 4
Snav's Avatar
I had the same question - so - mesh and mortar, yes?
Awesome :D
What about for the rest of the greenboard in a bathroom - when there is no transition between the two should a traditional mud be used? I've always wondered about mud in a high-vapor invironment.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 03-28-2010, 10:39 AM   #5
Drywall contractor
Rewards Points: 1,070
Traditional ready mix is fine. Use quality paint intended for bathroom application. Make sure you have adequate ventilation...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-28-2010, 10:50 AM   #6
Military Mom of 4
Snav's Avatar
Thanks, awesome.
Durock (CBU) to Drywall Transition HELP Honeydo_MD Drywall & Plaster 1 09-16-2009 12:24 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
Hardie Backer to drywall transition jnbrown Drywall & Plaster 1 12-27-2008 03:12 PM
Drywall to stone transition IraF16 Remodeling 4 03-18-2006 07:28 PM
Drywall to stone transition IraF16 Carpentry 1 03-17-2006 03:02 PM
