Durabond? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-24-2012, 10:16 AM   #1
Durabond?
I used Durabond setting type compound around an opening I cut out for a breakfast bar. I put drywall in the area I cut out with the original plaster still surrounding it. I had gaps between drywall and plaster and I was told to fill it in with Durabond mud. My question is can I use regular drywall mud over the Durabond mud? Or what kind of mud should I use to finish it? I still need to even out the plaster to the drywall because theyre faces weren't flush.
akeith40 is offline   Reply With Quote
Old 03-25-2012, 10:32 AM   #2
Drywall contractor
Rewards Points: 1,070
Yes you can use regular mud...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
using durabond as the base coat for veneer plastering zach081129 Drywall & Plaster 0 09-26-2010 10:31 PM
durabond 45 Millertyme Drywall & Plaster 3 09-20-2010 04:42 PM
Bubbling Durabond? jonathan03 Drywall & Plaster 2 06-11-2010 02:05 PM
Drywall - Durabond for patching a hole ccoulter350 Drywall & Plaster 6 03-06-2010 12:37 PM
Durabond "splotchy" T8RBUG Remodeling 3 03-03-2007 07:32 PM
