Dumb Question On Buying Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-27-2010, 09:11 AM   #1
Rewards Points: 640
dumb question on buying drywall
Alright this sounds dumb, but never had to buy it myself before... when you go to a place like lowes, drywall is always paired up in twos.... is the price per pair or per sheet? if you only need one sheet do you have to buy two or can you cut apart a set? how's it work? thanks
BlueBSH is offline   Reply With Quote
Old 05-27-2010, 09:49 AM   #2
fabrk8r
fabrk8r's Avatar
Price is per sheet.
Good question about buying one sheet! I've always bought an even number...just lucky I guess. There's always a yard hand around to help when I pick them up, so they would cut the paper strip for you. If you happened to be alone I'm sure you could cut the joining strip yourself and no one would care. I just tear them off at the job site to separate, but they might prefer it to be cut at the yard so the sheet could be identified on the edge.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 05-27-2010, 09:53 AM   #3
Rewards Points: 640
Originally Posted by fabrk8r View Post
Price is per sheet.
Thanks! yeah every time ive ever goten it someone else picked it up for me and it was strangely even numbers also... I need to replace one sheet right now on a wall....
Old 05-27-2010, 09:59 AM   #4
Household Handyman
Rewards Points: 1,408
We have three sources here for the public, and two for contractors only, for drywall. The big box places do allow a customer to cut/tear the strip to remove only one sheet. Actually I think they prefer the customer to do this as I can never find help to load anything at the big box stores. The contractor only places do all the work for us. David
Old 05-27-2010, 10:44 AM   #5
Drywall contractor
Rewards Points: 1,068
Yeah, it seems like at the big box stores the lot help always shows up after you've loaded 20 sheets by yourself and have 1 left on the cart.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 05-27-2010, 05:59 PM   #6
Rewards Points: 262
And the posted price is for one sheet, not two.
Jim F is offline   Reply With Quote
Old 05-27-2010, 07:52 PM   #7
Always a per sheet price. They come in twos so the good sides are facing each other and don't get damaged
masterofall is offline   Reply With Quote
Old 06-06-2010, 02:30 AM   #8
Rewards Points: 256
yes they ship them that way but you can buy one if you want . they dont care ... just like the 2x4s you can unbundle them and pick as many as you want.
oldrivers is offline   Reply With Quote
Old 07-20-2010, 07:07 PM   #9
buying drywall
I've never needed to buy drywall either.... is Lowes a good place to find it or is there another place to buy it for a better deal?
handyz is offline   Reply With Quote
Old 07-20-2010, 09:36 PM   #10
depot and lowes have the best prices more times than not on generic sheetrock. quietrock or cd board would require a specialty store. what are you using this sheetrock for? we might be able to help you avoid any mistakes if we knew the intended use.
racebum is offline   Reply With Quote
Old 07-22-2010, 08:19 AM   #11
i had the priviledge of stocking 3060 sheets of drywall lastnight, somehow i find myself reading about it this morning............
Bjamin is offline   Reply With Quote
Old 07-22-2010, 09:07 PM   #12
Originally Posted by Bjamin View Post
i had the misfortune of stocking 3060 sheets of drywall lastnight, somehow i find myself reading about it this morning............
fixed
Question about putting up drywall CZ DIY Building & Construction 5 02-25-2010 10:41 AM
dumb electrical question gbwillner Electrical 2 02-21-2010 09:34 PM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 03:30 PM
Another drywall question Curious Homeown Drywall & Plaster 3 11-09-2009 04:12 PM
very basic drywall question Knyte260 Building & Construction 3 07-18-2005 04:09 PM
