Drywalling Steep Stairwell Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-11-2011, 07:59 PM   #1
drywalling steep stairwell ceiling
i have to drywall the top of a stairwell they had water damage and the piece was hanging and had bad water damage
removing the old piece was easy.. up the later pull it down and cut it out and clean up
now to put up the new piece and tape it i cant figure out how im going to do that because its up 10-12 feet and below it is the steps going down if i was to fall down there it would be atleast a 24 foot drop and i cant see myself being able to hang the sheet let alone tape all 4 corners
am thinkikng about picking a comfortable working level and putting 2x4 on the walls screwing them into studs and then cutting a sheet of ply wood to sit on the 2x4s for a work area and then 1 2x4 across the sides so i dont slip and fall down the stairwell
ive hanged and taped lots of drywall before but never in these conditions
any help or suggestions would be great cause as safe as that sounds thats alot of work to then take down and patch up that work but painting the stairwell is the final step so its why ive thought of this
hope i hear back soon im suppose to start tomorrow
onedigita is offline   Reply With Quote
Old 04-11-2011, 08:56 PM   #2
DIY staff
Rewards Points: 7,174
Young follow----Whatever you do,be careful---
Old 04-11-2011, 09:15 PM   #3
Old School
Willie T's Avatar
Right now might be the time to bite the bullet and invest in a fairly expensive tool you can use for decades to come. These ladders are considered to be just about the best in the business, and can do a lot more than just adjust for stairs.
http://www.littlegiantladder.com/lit...t/type-1a.html
I suggest the model 22.
Willie T
Old 04-11-2011, 09:53 PM   #4
Handyman
Rewards Points: 512
Get yourself an articulating ladder and install in sections if you can't find a helper. Or set up up two ladders with a 2x12 board as a scaffold.
canadaclub is offline   Reply With Quote
Old 04-12-2011, 08:40 AM   #5
Rewards Points: 93
If you are in the US, the 22ft one made by Werner is on sale for $150 at HD. You can check store availability on HD's site. Just search for "MT22".
leungw is offline   Reply With Quote
Old 04-12-2011, 11:23 AM   #6
Old School
Willie T's Avatar
Around here, the good ones, the Little Giants, are always on Craig's list for $100 - $150. I got a brand new, unused one off Craigs list, with work platform and extending 'leveler' leg for $150.
Willie T
Tags
ceiling , drywall , stairwell
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
Ceiling fan issue - steep roof md2lgyk Electrical 4 10-04-2010 02:37 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Blending ceiling patch with existing sheet-rock (slight texture) gmhut Painting 3 07-29-2008 12:16 PM
