Drywalling Over Existing Drywall Questions - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-04-2010, 12:45 PM   #1
drywalling over existing drywall questions
Well I have to say this is something I have never attempted before so before I get started on anything I'd like to ask some questions to see if I should even attempt the job myself.
I am dealing with just one wall in a room and it is dry-walled, the other three are paneling and will remain that way.. It is covered in wallpaper. The job was done improperly from the start or there has been existing damage over time. There is an extremely large crack, minor to mild waviness, and it seems that all the pieces that were used don't square up. My main question is that if I were to drywall over this would these imperfections show through? Would the new drywall be wavy also? Would the new drywall have problems sitting on top of pieces that aren't sitting flush?
If problems would arise is there any ways to fix these occurrences without having to just demo the wall? To me it looks like they wallpapered because of how much they messed up on the drywalling. Well any help is much appreciated. Thank you.
keenon is offline   Reply With Quote
Old 03-04-2010, 01:34 PM   #2
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
You may want to dig a bit more into your issue rather then try to cover it up. The studs may not be correct the drywall may have not been installed right........so on. Take a pic or two and post them. That will help us help you LOL
Big N8 is offline   Reply With Quote
Old 03-06-2010, 09:18 AM   #3
Drywall contractor
Rewards Points: 1,070
Agree with N8, a pic would help. You could have some framing issues (bowed/cracked studs) causing some of the problem. That would require demo to fix....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is online now   Reply With Quote
Old 03-06-2010, 12:01 PM   #4
Agree with above post... with the issues you describe it would be prudent to take a look at least behind the existing wall you want to rock over.
Benefit to remove existing drywal: inspect for problems....where did those bugs come from? opportuity to correct frameing, insulation, add electrical... trim issues minimized..etc..
Benefit to Rockover: Little less mess and debris to deal with.
You will need to cut down your trim to fit new dementions and add extenders to electrical boxes.
Big Bob is offline   Reply With Quote
Old 03-08-2010, 01:26 PM   #5
I'm sorry guys for taking so long to return a reply. Well looks like I will never get to find out what would have been better. This was a project I was going to do for my parents...well once I mentioned the possibility of having to demo the wall they canned the idea and decided to just fix what they can and re-wallpaper over it...Yea I'm not in favor, but maybe that is simply because I am not a fan of wallpaper...Just for fun I'll put some pics up anyway
So yea here are some pics...It might be hard to see what is going on in each picture. The first one is showing the waviness. The second pic is showing the huge crack. The third pic is showing the crack again plus some bubbling on the right side. The fourth pic is showing a seam popping through and also next to the entertainment center around the area where there is a glare showing you can see where two pieces of drywall obviously aren't flush with each other. Anyway any advice would be great even though it sounds like the job won't be done. Thanks a lot guys.
A few questions on skim coating, matching drywall texture, and corners Scott99999 Drywall & Plaster 9 12-08-2009 05:17 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Drywall over existing ceiling? Curious_16 Drywall & Plaster 7 04-15-2009 07:38 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
