Drywalling Around Window And Drywall Rip Questions - Drywall & Plaster - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-20-2012, 11:40 AM   #31
Experienced
Jackofall1's Avatar
Originally Posted by kid tech View Post
titanoman,
how will lay out the tape if i have the rip in the middle? do i have to used two strips or just a wider tape?
thanks
Can't wait to here this one.......
Old 01-20-2012, 11:42 AM   #32
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Originally Posted by Jackofall1
u mean leave a 2" gap at the bottom and cover it with the baseboard? then i will have to put a really wide base trim to cover the 2" gap and the ~3" of the drywall tapered edge...i want a trim no wider that 3.5"
thanks
3.5" trim will be fine, if you leave that gap in the middle you will have a heck of time finishing it! It will look like crap! and after going through the effort of leveling and insulating, I would bet you want something that looks half decent when you are finished.
Mark[/QUOTE]
I just can't help but jump back in here. There's no reason it would like like crap any more than a single seam.
That's an ignorant statement.
And you're going to drive the op into having to buy a bigger baseboard.
Op: This guy doesn't seem to know a lot about drywall if you ask me. Do what you know is right.
titanoman is offline   Reply With Quote
Old 01-20-2012, 11:43 AM   #33
Disabled wood vet
titanoman's Avatar
titanoman,
thanks
Yes. 2 runs of tape. By the time you're done with a 12" knife, it will be a beautiful thing.
Old 01-20-2012, 12:38 PM   #34
Experienced
Jackofall1's Avatar
You might want to read the attached.
I am not trying to be arguementative, I have hung and finished DW DIY for many years now and I can tell you through experience, leaving a 2" gap and trying to finish that will be far more difficult than you think.
The compound if applied to heavily will shrink and crack not to mention how much sanding you will have to do if you get the compound built up enough to cover a 2" gap.
Read this.....http://www.usg.com/rc/installation-a...de-en-J371.pdf
One of the tips in this is keep the joint tight, and avoid butt (non tapered) joints.
OK thats it, its all up to you now.
Mark
Old 01-21-2012, 12:06 AM   #35
You want the horizontal seam (the one you have to mud) tight, leave the gap at the bottom where it will be covered by base trim.
u mean leave a 2" gap at the bottom and cover it with the baseboard? then i will have to put a really wide base trim to cover the 2" gap and the ~3" of the drywall tapered edge...i want a trim no wider that 3.5" thanks[/quote]
There is a trim that is nominally 4" boards ... you can get at H Depot or Lowes & probably most everywhere. It consists of 4' square rosettes for the corners, and plain or fluted board for around the window (or in door kits) that is retro in effect and, I think, cool for your older house. THAT would handle the 2" around the window. As for the adjacent wall, 2" strip will easily nail/screw to studs & finish out the drywall. Mud covers a multitude of sins, of course. Almost ALL sins!
bareshiyth is offline   Reply With Quote
Old 01-21-2012, 12:45 AM   #36
Disabled wood vet
titanoman's Avatar
There is a trim that is nominally 4" boards ... you can get at H Depot or Lowes & probably most everywhere. It consists of 4' square rosettes for the corners, and plain or fluted board for around the window (or in door kits) that is retro in effect and, I think, cool for your older house. THAT would handle the 2" around the window. As for the adjacent wall, 2" strip will easily nail/screw to studs & finish out the drywall. Mud covers a multitude of sins, of course. Almost ALL sins![/QUOTE]
Old 01-21-2012, 12:45 AM   #37
Disabled wood vet
titanoman's Avatar
And that base won't match the rest of the house.
Old 01-21-2012, 12:46 AM   #38
Disabled wood vet
titanoman's Avatar
[QUOTE="titanoman"]
Old 01-21-2012, 10:41 AM   #39
Experienced
Jackofall1's Avatar
As it was never mentioned, I am wondering how in the world you would know what existing trim looks like.
And why in the world would you create a sin that would have to be fixed with mud, its an almost virgin wall, put the drywall in correctly to begin with and the mudding is much simplier, and, I will say it again trying to fill a 2" gap (that doesn't need to be there) is just plain crazy!
Mark
Old 01-21-2012, 10:47 AM   #40
Rewards Points: 1,450
I have to agree. Filling a two inch gap is silly and the fact that it doesn't even need to be there is worse. It may look fine at first, but chances of it cracking in the future are probably very good.
mikegp is offline   Reply With Quote
Old 01-21-2012, 11:10 AM   #41
thanks all for all your help with this. it is not filling the gap entirely with mud, there will be a 2" drywall strip in there, therefore creating two seams. this picture shows exactly what i will end up with. will this be difficult to mud??
kid tech is offline   Reply With Quote
Old 01-21-2012, 11:13 AM   #42
Experienced
Jackofall1's Avatar
You can finish that, its much harder but very possible, I would personally put the 2" strip at the bottom where the finishing is mostly covered by the baseboard.
Mark
Old 01-21-2012, 11:18 AM   #43
jack, if it was a 4 " or 5" inch situation, where would you put it?
Old 01-21-2012, 11:21 AM   #44
That won't be difficult to mud at all. The strip makes it much better than what I was picturing. Still not the best case scenario, but should work. I would just use three pieces going across horizonatally, but that's just me.
Old 01-21-2012, 11:28 AM   #45
mike, how wide would u run the pieces?
Drywall instead of trim around window MP_777 Drywall & Plaster 12 02-09-2011 09:26 AM
Covering a window with drywall bobbysgirl Building & Construction 6 11-25-2010 09:35 PM
My window between siding and drywall... jamieofansa Drywall & Plaster 2 09-05-2010 08:55 PM
how to fix the drywall around window frame.... Skipper1977 Building & Construction 1 05-10-2010 08:46 AM
Single Hung Window Removal for Drywall bparise Drywall & Plaster 2 12-12-2009 07:44 AM
