Drywalling Around Window And Drywall Rip Questions - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-20-2012, 09:24 AM   #1
Drywalling around window and drywall rip questions
Hi all, i am new to this site and i have a few questions
I need to know how to drywall around this window, there are about 3" - 4" from the closest stud to the window frame. will i need backing to screw the drywall closer to the window frame or is 3"-4" close enough??
The other issue i am having is with the wall which is 8' 2'' tall. where should i put the 2" rip, in the middle or at the bottom? i am leaning towards having the rip in the middle but would like to know about mudding it since there will tapered and non tapered edges seaming..
thanks in advance for your help.
kid tech is offline   Reply With Quote
Old 01-20-2012, 09:29 AM   #2
Rewards Points: 1,480
Do you have a picture? Why can't you add another stud?
mikegp is offline   Reply With Quote
Old 01-20-2012, 09:30 AM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I don't understand why your nearest stud is so far away. What are you going to nail your trim to?
You kind of need to get something in there closer if you can.
Yes, put the rip in the center and don't worry about the tapered edge butting a non-tapered edge.
titanoman is offline   Reply With Quote
Old 01-20-2012, 09:39 AM   #4
having trouble with the pictures, they are too large...will re-size and post
Old 01-20-2012, 09:55 AM   #5
pics
ok here they are..
Drywalling around window and drywall rip questions-img_3931-480x640-.jpg   Drywalling around window and drywall rip questions-img_3935.jpg   Drywalling around window and drywall rip questions-img_3938.jpg
Old 01-20-2012, 09:57 AM   #6
the board will not lay on top of the window frame but flush on the side
Old 01-20-2012, 09:59 AM   #7
Slap another stud in the cavity on each side of the window. Spray foam in there while you're at it. Seems simple unless I can't see something in the pics that is really there.
Old 01-20-2012, 10:03 AM   #8
Also, it looks like the wall is built entirely wrong around the window. King studs, jack studs, etc, but I'm not an expert on framing.
Old 01-20-2012, 10:25 AM   #9
Disabled wood vet
titanoman's Avatar
Yes. Actually, all that framing should be ripped out and re-done completely.
Old 01-20-2012, 10:26 AM   #10
thanks mike, the house was built in the 1930's, i removed the plaster to replace with drywall and shimmed the wall to even it out and make the board flush with the window jambs.
Old 01-20-2012, 10:31 AM   #11
Disabled wood vet
titanoman's Avatar
Now that I see the pictures...
Who built this wall?
What's holding the window in?
That wall is horrible. It needs a header. It needs to be framed the right size for that window.
Old 01-20-2012, 10:37 AM   #12
it is not a new wall since it was built in the 1930's. those shiny new studs you see there are just shims the old studs is behind...the window itself has a 1 x frame all around
Old 01-20-2012, 10:41 AM   #13
oh my, does that mean taking the window out???
Old 01-20-2012, 10:58 AM   #14
Experienced
Jackofall1's Avatar
Leave the 2" at the bottom of the drywall you what that horizontal seam tight. The 2" at the bottom will be covered with base trim.
Looks like that window is a replacement set in the existing framing and the wall is built on to the existing wall, so the header is already there.....right? In which case you will be fine, but you do have to think about how you are going to connect the window casings, if there is nothing to nail to how will you hang the trim?
Mark
Old 01-20-2012, 11:05 AM   #15
Experienced
Jackofall1's Avatar
Maybe you should ask some questions first and then make suggestions based on the answers, instead of blasting blindly. Just a suggestion.
Mark
Drywall instead of trim around window MP_777 Drywall & Plaster 12 02-09-2011 09:26 AM
Covering a window with drywall bobbysgirl Building & Construction 6 11-25-2010 09:35 PM
My window between siding and drywall... jamieofansa Drywall & Plaster 2 09-05-2010 08:55 PM
how to fix the drywall around window frame.... Skipper1977 Building & Construction 1 05-10-2010 08:46 AM
Single Hung Window Removal for Drywall bparise Drywall & Plaster 2 12-12-2009 07:44 AM
