Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 05-16-2013, 04:49 PM   #1
Renovating My Land Yacht
Drywalling around knee walls etc....option A or B
Not even going to try and explain this sooooo..........
Lets say on the below image, the black is a framed beam or knee wall that needs to be covered in drywall. The red is the drywall. I left gaps so to speak so you can understand what I am talking about.
Do you use option A or B for wrapping beams, knee walls and other bits and pieces that stick out from the walls? Does it matter or is one stronger than the other or does the corner bead take care of it either way?
Robyn
forcedreno2012 is offline   Reply With Quote
Old 05-16-2013, 06:22 PM   #2
Both ways will work but your still going to need outside corner moulding to cover the outside edges.
http://www.bing.com/images/search?q=...bead&FORM=IGRE
Please edit your profile so it shows your location!
No one here knows exactly where on the planet you may be so how can we ansewer a code, building, or insulation question without it?
Old 05-16-2013, 06:50 PM   #3
it's really doesn't matter. it's not uncommon to do like this either.
(thumbnail isn't working, but the link does)
Seattle2k is offline   Reply With Quote
Old 05-16-2013, 07:12 PM   #4
I was surprised that nobody mentioned that being bad in the thread about a bad drywall job. I didn't realize that was acceptable. I think it's a bad idea especially with metal corner bead.
Dorado is offline   Reply With Quote
Old 05-16-2013, 07:58 PM   #5
automated tool pro
A.....
drywallfinisher is offline   Reply With Quote
Old 05-16-2013, 08:39 PM   #6
ya do A. i always fill in with the left over scraps and that small piece is larger and less likely to break when installing it.
princelake is offline   Reply With Quote
Old 05-16-2013, 10:01 PM   #7
Thank you all. A it is then. Wasn't sure if there was a set way to do it.
Robyn
Is it possible for opposing knee walls to be exactly parallel ?? FileOpen Building & Construction 8 02-15-2013 08:01 PM
Insulation quandary (knee walls with photo) kevabar Insulation 5 01-10-2013 11:01 PM
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 07:09 PM
attic knee walls gregt848 Building & Construction 2 09-27-2009 12:07 PM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing 4 02-18-2008 03:50 PM
