Drywalling Around A Corner Door - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-23-2013, 05:00 PM   #1
Drywalling around a corner door
I am currently working on a bathroom that has a door very close to an inside corner. With the studs exposed there is about 2 inches from the corner stud to the outside of the jamb. It's not possible to move the door over. How should I attempt to finish that? Do I treat it like a normal inside corner/door and tape it or do I take score a strip on the adjacent sheet and fold it into the corner using the front paper like a book binding? I had a person tell me that was how he did all of his corners. I have done several drywall projects and have worked for a short time on a drywall crew but I've never had to deal with a door that was so close.
SoapDish is offline   Reply With Quote
Old 07-23-2013, 07:59 PM   #2
Rewards Points: 512
i'd tape it.
your door casing will probably cover most of it
princelake is offline   Reply With Quote
Old 07-23-2013, 08:09 PM   #3
Old School
Willie T's Avatar
It will add 10 or 15 minutes to the job, but for perfection, just remove the door casing first. Put it back on when you're done.
Willie T
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 09:24 AM
Storm Door Selection/Brand Advice Wanted kc27 General DIY Discussions 3 10-25-2009 08:17 AM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 07:22 AM
Fitting Door Closers clayton1302 Carpentry 6 05-09-2009 08:09 AM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 08:43 AM
