Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 09-08-2009, 07:18 PM   #1
Drywall on wall just over 8ft.
Whats the best way to hang drywall on walls that are 8ft 1-1.5".
I have added some plywood to the floor for some support for tile. That has brought the hight so theres not much more of the base 2x4 showing on the bottom of the walls (maybe 1/2"). Now measuring from the floor to ceiling its around 1-1.5" over the 8ft mark. So wheres the best place to put the gap and how to cover and such. Thanks JIM
integlikewhoa is offline   Reply With Quote
Old 09-08-2009, 07:20 PM   #2
Xtreme DIY'r
Ceiling rock goes up 1st
That's 1/2" less
If you will have baseboards I use scrap at the bottom to make up the difference
Old 09-08-2009, 07:23 PM   #3
joed's Avatar
Agree. Use scrap at bottom. Might not even need to tape and mud it if the baseboard is covering it. Could probably even be filled in with scrap lumber just to keep the baseboard vertical.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 09-08-2009, 08:59 PM   #4
Old School
Willie T's Avatar
http://www.gypsum.org/pdf/GA-216-07.pdf
The site included here will show you tons on how to do this job.
Willie T
Old 09-08-2009, 09:18 PM   #5
Tool Geek
PaliBob's Avatar
Most Supply Houses carry a tool similar to this:
http://www.amazon.com/Diversified-Po...2458817&sr=1-2
& Stay Safe
.....Bob Lavery
Old 09-09-2009, 11:45 AM   #6
Sorry, forgot to say that ceiling is already on. So push the upper and lower panels up tight to the ceiling and put a small strip on the bottom to fill what ever is left.
I didn't know it if was say a 1/2"-3/4" gap if you would fuge the pieces to fit. Say leave a 1/4" gap on the bottom top and middle or such and when you tape cover them up.
Old 09-09-2009, 11:53 AM   #7
Old School
Willie T's Avatar
The point in doing the ceiling first (and, of course, leaving the edges unfastened) is to shove the upper wall sheets up tight against the ceiling pieces, thereby helping produce a nice, straight wall-to-ceiling edge all the way. Then you use a toe jack to snug the lower wall sheets up against the upper wall sheets.
The space left at the bottom is no big deal. I usually use a ripped piece of 1/2" plywood down there so I can nail my baseboard anywhere I choose.
Willie T
Old 09-09-2009, 11:58 AM   #8
Thanks for you help. The plywood I never thought of or seen, but seems like a good idea.
Old 09-09-2009, 12:02 PM   #9
Newbie Bill
Wow great idea. This is why I hang out here.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 01:05 PM
Considerations when pouring concrete against a stucco wall? clint_nichols Building & Construction 9 09-24-2009 06:28 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Drywall over existing wall? benbuchwalter Remodeling 3 02-21-2008 11:57 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
