Drywall Vs Plaster - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-07-2013, 07:12 AM   #1
Drywall vs plaster
hello all, thank you for the forum.
We are considering Plastering our new addition on our home, but the cost of plaster is extreme compared to the drywall method. should we save for the cost of plaster or should we go with the drywall?
I have a drywall supplier that quoted me for plasterboard, but he does not sell 16' regular drywall gypsum board. So if I change to regular drywall I will now have to have butt joints. Or should I buy it elsewhere and basically have wasted this guys time.
One more thing should I even consider hanging the drywall myself and put the money into getting a better finish on the drywall. I was thinking a level 5 finish. Does anyway know what the cost of doing that is?
Okay, I hope you can follow this post, because I seem to be having trouble being clear this morning.
thank you,
jen2013 is offline   Reply With Quote
Old 07-07-2013, 07:48 AM   #2
Rewards Points: 13,750
Often times plaster is a local thing. In the past 40 years living on the east coast I've not seen any new construction using plaster.
What makes you think you need a level 5 finish?
Any decent drywall crew could have that rock hung and paint ready in as little as three days. If you have never installed sheetrock before that time frame is just not going to happen.
Butt joints are no big deal, some hangers use what called butt boards to create a low spot where it's taped.
http://www.buildsite.com/pdf/trimtex...ure-330267.pdf
ToolSeeker (07-07-2013)
Old 07-07-2013, 08:53 AM   #3
Six kids is why I am looking at something more than just standard drywall. We have more dings in drywall than I can to look at. I think part of our problem is that we should have painted the walls more than just the two coats that are on there and maybe that is why we get dints easily. Plus I think we had cheap wallboard before.
I think we will go the route of regular drywall, but I was interested in what others thought on the topic.
Thank you
Old 07-07-2013, 10:19 AM   #4
Drywall would be far easier to repair.
A level 5 will gain you nothing but a higher bill to do the job.
Paint is not going to prevent dings.
Old 07-07-2013, 10:55 AM   #5
Rewards Points: 512
buy some abuse board http://www.cgcinc.com/en/products/pa...aspx?pType=PRO
its used in alot of hospitals, hotels, etc. it would also work perfect for your application.
princelake is offline   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
Old 07-07-2013, 04:52 PM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 396
If you can afford plaster, then by all means do it. It is a far superior to drywall.
The Following User Says Thank You to chrisn For This Useful Post:
drywallfinisher (07-12-2013)
Old 07-07-2013, 07:39 PM   #7
Rewards Points: 5,974
In some ways.
Old 07-08-2013, 04:17 AM   #8
chrisn's Avatar
Rewards Points: 396
most ways
Old 07-12-2013, 12:44 PM   #9
Mold!! Let's kill it!
Rewards Points: 2,012
I would at least use impact resistant drywall as was mentioned above.
Old 07-12-2013, 09:55 PM   #10
automated tool pro
Rewards Points: 152
totally agree. The plaster two coat systems are far superior. You save your cost in the cost of the paint and it creates a much healthier environment to live in. If you dig into it and read about the specs and what not, it saves on utility cost as well and has a longer life than drywall. Its far superior. about a $1.75 a ft around here. Calcite based over blue board twice. Looks kick ass when finished as well. I hear nothing but good things regarding this system.......be clear it isnt american clay. that mix is crap..
drywallfinisher is offline   Reply With Quote
Old 07-14-2013, 09:10 AM   #11
Rewards Points: 626
Thank you
there are sheetrock pannels that are made to hold up to high abuse. they are not found at the box stores. you have to buy them from a drywall supply store.
Nailbags is offline   Reply With Quote
How do you intersect drywall (or in my case plaster) into tile on the same plane? Proby Kitchen & Bath Remodeling 5 08-02-2010 05:51 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Drywall over plaster? Rob1980 Drywall & Plaster 10 04-11-2009 05:05 PM
Can you adhere drywall to plaster? whiskeykid Drywall & Plaster 9 08-15-2008 07:42 AM
Joining drywall and plaster pete1972 General DIY Discussions 5 10-28-2006 05:08 PM
