Drywall Vs Concrete Vs Soundproofing - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-03-2012, 04:48 PM   #1
Rewards Points: 150
Drywall Vs Concrete vs Soundproofing
On a staggered wall designed to be soundproof, my multiple layers of sheetrock will end up about 1"-1 1/4" from the concrete subfloor. This is a bit high (although the floor plate will be covered).
One solution would be to cut off 7" from the bottom sheets of the bottom layers and add a 7 1/2" strip. This will give me 1/2" to 3/4" from the concrete, but may limit my options later (floor-wise). Additionally, a 3/4" or so strip of sheetrock along the bottom (multiple layers) would tend to be crumbly and unstable.
The question: is there a better way to approach this, i.e., a sound dampening foam or rubber stripping (both of which should be able to receive caulk) that could be applied after the floor is in?
Thanks!
rightit is offline   Reply With Quote
Old 06-03-2012, 06:51 PM   #2
get longer rock. it sounds like you are laying this down (horizontal).
you can get rock at 54" wide, 6 inches more than regular 48 inch.
if you are standing up (vertical), you can get rock in 8, 9, 10, 12, 14 and 16 ft lengths.
sevenlol is offline   Reply With Quote
Ceiling - Green Glue & Drywall for Soundproofing mvt2k7 Building & Construction 7 05-29-2012 05:58 PM
Repair hole in drywall installed on concrete optimizer Drywall & Plaster 5 04-18-2011 10:19 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
How should I fur for drywall, along a concrete stairwell Buffalo4 Drywall & Plaster 7 11-28-2009 06:52 PM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 12:03 PM
