Drywall Under Stairs - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-08-2012, 07:59 AM   #1
Rewards Points: 97
Drywall under Stairs
Hello.
The stairs leading to my basement are about 38" wide. There are stringers on the sides and I can attach the drywall there. How do I support the drywall in the middle without a stringer there?
Thanks.
leungw is offline   Reply With Quote
Old 06-08-2012, 02:46 PM   #2
Rewards Points: 744
Add in additional stringers for support, or cover the area with plywood, before attaching the drywall.
Seattle2k is offline   Reply With Quote
Old 06-08-2012, 03:34 PM   #3
Could you add 2x4s horizontally on 16" centers between the stringers and screw the drywall to that? On the flat, you'd only lose 1 1/2" height over attaching the drywall directly to the stringers.
jbs11 is offline   Reply With Quote
Old 06-10-2012, 03:03 PM   #4
Rewards Points: 97
Thank you.
Cutout in drywall around sink coutertop bananey Drywall & Plaster 4 05-04-2011 04:47 PM
Cutting drywall side of basement stairs? Oxymoron Drywall & Plaster 4 10-07-2010 09:13 PM
drywall existing stairs that have carpet Peggers Drywall & Plaster 2 02-20-2010 01:12 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
drywall on stairs goodman Carpentry 11 03-20-2005 10:45 AM
