Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 11-12-2011, 12:37 PM   #1
jc8
Drywall/tub surround
When installing drywall behind a tub surround, should it stay above the lip of the tub?
jc8 is offline   Reply With Quote
Old 11-12-2011, 07:02 PM   #2
Super Moderator
More details---drywall is not allowed in a wet are in the U.S. what are you doing exactly--
Old 11-12-2011, 09:59 PM   #3
jc8
I'm replacing the tub surround. I actually called a buddy and he suggested leaving it above the flange. So that's what I've done. I used the dens-shield.
Old 11-12-2011, 10:03 PM   #4
Super Moderator
You are good----that is the correct way---Mike---
Old 11-19-2011, 07:50 PM   #5
jc8
I have put in dens-shield above the tub flange, but it sticks out over the top, so that there is not a solid line from the tub straight up. I'm concerned this is going to be a problem for the tub surround sticking/not buckling. I also am wondering if there is any negative effects to putting the shiny side of the tub surround against the wall?
Is H20 resistant sheetrock ok behind an f-glass surround? Jeffrey H Plumbing 6 11-01-2010 07:30 PM
Surround Sound Hookup Options Branden Home Theater 3 10-06-2010 03:40 PM
Tiled Shower Surround Help CluelessNewbie Kitchen & Bath Remodeling 4 02-10-2010 10:33 AM
Gap in Corner Between Tub Surround and Bathtub? Howitzer Remodeling 12 09-17-2008 05:14 PM
Tub surround shower door issues Zharkov Plumbing 14 06-30-2008 11:52 PM
