Drywall Transition? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-21-2010, 04:21 PM   #1
drywall transition?
I am working on installing a swanstone shower surround and want to add another layer of drywall (GB)for proper tub lip overhang spacing. My problem is how to finish the joint where the new 1/2" drywall is lapped over the existing drywall wall. Can I just use paper tape formed into a z like shape? thanks
tigman is offline   Reply With Quote
Old 02-21-2010, 05:21 PM   #2
Why not
find a tile that has a transition to slope over to the new drywall. should be easily found in ceramics
noahweb is offline   Reply With Quote
Old 02-21-2010, 05:52 PM   #3
thanks for the reply noahweb.
The swanstone is the thin fiberglass type. I just want to end the GB on top of the existing drywall with a step.
Old 02-21-2010, 08:03 PM   #4
getting ready to do one myself, they make trim packages for the edges. when i talked to swan corp they also said to do 2 coats of latex (not oil) primer versus the one coat in their pdf instruction manual. its worth calling to check on any changes on install that hasnt made it to their online instructions. let me know how it goes, mine starts this week
The older I get the better I was
Improving a bad tile to drywall transition navi_jen Drywall & Plaster 6 11-27-2013 10:56 AM
drywall transition joint ? tigman Building & Construction 0 02-20-2010 04:52 PM
Hardie Backer to drywall transition jnbrown Drywall & Plaster 1 12-27-2008 03:12 PM
Drywall to stone transition IraF16 Remodeling 4 03-18-2006 07:28 PM
Drywall to stone transition IraF16 Carpentry 1 03-17-2006 03:02 PM
