Drywall Thickness For Ceiling? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-07-2008, 12:27 PM   #1
The Big Builder
Drywall thickness for ceiling?
Hello everyone,
I am finishing the basement of my 50s ranch and was wondering what the thickness of the drywall should be for the ceiling. There is a little flex to the ceiling so I a conceerned abotu cracking at the seams. Do I use thicker sheets to be stiffer or thinner sheets for reduced weight?
Any other tips would also be appreciated.
Thank You,
Stephen
bigbavarian is offline   Reply With Quote
Old 07-07-2008, 04:07 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
This depends on the distance between your ceiling framing members. 24" O.C.? 12" O.C.?
Generally, it is best to have your ceiling framing members at 16" OC for any thickness sheetrock (exception: 12" OC for MR board). If you don't have it, add the additional framing.
Once this is done, if you are concerned about flex/sag/etc...Then you could install 5/8" on the ceilings (with 16" OC framing) and 1/2" on the walls.
Good Luck...and check that framing!
- Build Well -
Old 07-07-2008, 08:26 PM   #3
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 892
I'd use either 5/8" or 1/2" ceilng board(made specifically for ceilings).
Sir MixAlot is online now   Reply With Quote
Old 07-07-2008, 08:59 PM   #4
Ceiling drywall? Any links?
jerryh3 is offline   Reply With Quote
Old 07-07-2008, 09:36 PM   #5
K&B Remodeler/Tile Guy
angus242's Avatar
http://www.gp.com/build/product.aspx?pid=5435
Angus
My Albums
angus242 is offline   Reply With Quote
Old 07-08-2008, 07:09 AM   #6
The Big Builder
Great tip guys. I never knew there was drywall made especially for ceilings.
Stephen
Old 07-08-2008, 07:54 PM   #7
Rewards Points: 892
Glad we could help you out. Have fun!
Old 07-20-2008, 09:07 AM   #8
HomeAdditionPlus.com
Rewards Points: 29
First, if you are going to install drywall on the basement ceiling, I would add strapping (1"x3") on 16 O.C. perpendicular to the bottom of the first floor floor joists. This will strengthen the area for hanging drwall.
I would also use 5/8" sheetrock on the ceiling.
Last edited by AtlanticWBConst.; 07-20-2008 at 12:55 PM. Reason: DIY Chatroom Rules Violation: Site Link Removed
mjdonovan is offline   Reply With Quote
Old 07-20-2008, 03:25 PM   #9
BUILDER / REMODELING CONT
buletbob's Avatar
GP Tough-Rock
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 12:05 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
drywall question billyg Drywall & Plaster 3 08-01-2008 09:49 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
