Drywall Thickness - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-30-2011, 04:22 PM   #1
Drywall Thickness
Hi All,
I'm building a room in my basement and most of the walls will be free standing partitions made of 2x4's. Part of one wall will be made of drywall on firing strips attached to concrete blocks.
I'd like to use 3/8" drywall simply because it's lighter and easier to work with.
Is this the correct choice for my application?
I'm planning to also install drywall on the ceiling.
Thanks in advance,
Bob
Bob Guercio is offline   Reply With Quote
Old 09-30-2011, 04:33 PM   #2
Old School
Willie T's Avatar
1/2" is a better choice for your walls. And although some municipalities now allow regular 1/2" for ceilings, drywall made specifically for ceilings may resist future sagging better.
Willie T
Old 09-30-2011, 04:40 PM   #3
Is the drywall for ceilings that which is 5/8" thick?
Old 09-30-2011, 04:44 PM   #4
Old School
Willie T's Avatar
Usually. But, as I said, some places let you use 1/2" now. Me, I guess I will always use 5/8", mostly out of habit and tradition.
Willie T
Old 09-30-2011, 04:46 PM   #5
I would definately use something like GP's Densarmor Plus. A Basement is alway going to be at risk of flooding. Water just beads on Densarmors surface, It is also much stronger than regular drywall although it does weigh a lot more. As far as running the board on furring strips over concrete, just be sure to apply a concrete sealer to the inside first, to keep moisture from getting at the furring strips. As far as the ceilings go, I'd use 1/2" drywall, and make sure to go perpendicular to the frameing(48" or 54" direction should be parallel to the framing, each sheet should touch 6 rafter/joists.
Dustincoc is offline   Reply With Quote
Old 09-30-2011, 06:11 PM   #6
Does 3/8" drywall have a valid use or is it a product that you should just stay away from?
Bob
Old 09-30-2011, 06:44 PM   #7
Old School
Willie T's Avatar
Bob
It's used mainly to simply cover original, messed up wall surfaces.
Willie T
Old 09-30-2011, 09:15 PM   #8
I'd like to thank you guys for responding to my thread and helping me with this issue.
Bob
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 02:08 PM
Drywall ceiling above bathtub/shower larabiec Drywall & Plaster 3 06-26-2011 02:23 PM
Framing for Drywall Ceiling Wino Building & Construction 1 01-13-2010 03:05 PM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 03:30 PM
What Thickness Drywall To Install Over Acoustic Ceiling? dsq Drywall & Plaster 12 02-08-2009 08:27 AM
