Drywall To Textured Ceiling Joint Finishing - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-26-2010, 06:36 PM   #1
Drywall to Textured Ceiling Joint finishing
I have just completed a shower surround install, and need to replace about a 12" strip of Denseboard along the top of the surround. How can I finish the corner where the wall meets the textured ceiling. I don't want to remove the ceiling drywall, or the texture for that matter. Any ideas ? Can the wall just butt against the ceiling and be caulked or mudded ?
tmbrink is offline   Reply With Quote
Old 01-26-2010, 09:32 PM   #2
firehawkmph's Avatar
Rewards Points: 1,864
Tm,
No and no.
Take a 4" knife and scrape the texture on the ceiling down so it is somewhat smooth. Tape the corner. I like using the nylon mesh tape, some guys don't. Keep the mud on the ceiling in the 4" space you cleaned up. After you are done coating and both wall and ceiling patch are smooth, just go back and texture the 4" strip blending it into the rest of the ceiling. Depending on the texture pattern you have, natural sponges work well for this or the round horsehair brushes.
Mike Hawkins
Can the wall just butt against the ceiling and be caulked or mudded ?[/quote]
firehawkmph is online now   Reply With Quote
Old 01-27-2010, 11:12 PM   #3
Spray cans of texture are available at just about any hardware store. Cost around $10 - $12. They are made just for this type of repair or patch. Follow firehawk suggestions. If the texture is small enough it can be taped and mudded over.
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
Old 02-04-2010, 10:03 AM   #4
Drywall contractor
Rewards Points: 1,070
Mesh tape is not intended for use in corners. Some use it anyway. If you do, make sure to use a setting type compound on at least the first coat....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Drywall ceiling in basement using floor trusses ralphfravel Drywall & Plaster 10 04-03-2009 07:12 AM
What is the best way to paint a textured Ceiling? earthad1 Painting 8 03-18-2009 08:14 AM
Drywall over existing ceiling? billybarty Carpentry 1 03-07-2008 11:05 PM
Drywall finishing JimmieC Building & Construction 4 07-07-2006 05:26 AM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 08:27 AM
