Drywall Texture Help - Tear Drop Shapes? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-06-2009, 02:22 PM   #1
Can anybody give me a hint about how to get a shape like this for my texture. I'm replacing a 4x8 sheet of drywall and want to match the texture.
Any ideas on how to create such a "tear drop" style texture?
Thanks!
Oscarthegrouch is offline   Reply With Quote
Old 07-07-2009, 02:56 PM   #2
NAV
Looks like they watered down the drywall mud quite a bit and rolled it on.
you should try different consistences of plaster and different nap rollers.
good luck
NAV is offline   Reply With Quote
Old 07-08-2009, 10:33 AM   #3
Drywall contractor
Rewards Points: 1,070
I'd have to agree with NAV. Try a 3/4" or 1" nap roller and thin your mud. Consistency should be almost like pancake batter, maybe just a bit heavier. Add water gradually until you get the right texture.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 07-26-2010, 02:23 PM   #4
Did you ever figure out how to recreate this texture? I just bought an odler home and I am attemptign to repair a part of the wall that currently houses a window unit. Yes, a window unit in a wall... The walls have this texture and I can't find out how to recreate it anywhere.
Danielle14303 is offline   Reply With Quote
Tags
dry , drywall , texture , wall
Using drywall for Drop Ceiling rickkeeter Drywall & Plaster 8 02-13-2009 07:52 AM
drywall texture time.. any recommendations? SKINNY Drywall & Plaster 6 10-23-2008 11:42 PM
Toping Compound for texture....before or after drywall primer? yummy mummy Building & Construction 6 05-04-2008 10:57 PM
Steps for putting texture on new drywall TNeat Remodeling 4 12-22-2007 06:39 AM
