Drywall Texture...Help! - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-20-2016, 02:35 PM   #1
Rewards Points: 4
Hi, I'm remodeling a room in my house and have replaced some drywall. Can anyone verify what the texture of my walls are? It looks like orange peel..but i can't be sure.
Also, is there any way to replicate this texture with a roller? or would i have to use a hopper?
Any help would be appreciated!
DIYGAL888 is offline   Reply With Quote
Old 06-20-2016, 04:20 PM   #2
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 876
Re: Drywall Texture...Help!
Yep That's an orange peel texture.
I have had good success matching orange peel texture with the can texture and also with the orange peel texture sponge or a hopper and compressor.
Here's a couple of my videos on youtube.
Sir MixAlot is offline   Reply With Quote
The Following User Says Thank You to Sir MixAlot For This Useful Post:
DIYGAL888 (06-20-2016)
Old 06-20-2016, 05:20 PM   #3
Rewards Points: 144
Just remember Sir Mixalot as well as myself have had many of years of experience matching these textures.It may not be as simple as it looks in his videos to get it correct.Not rocket science,just saying!
mako1 is offline   Reply With Quote
The Following 2 Users Say Thank You to mako1 For This Useful Post:
DIYGAL888 (06-20-2016), Sir MixAlot (06-20-2016)
Old 06-20-2016, 05:32 PM   #4
Rewards Points: 4
Thanks so much for the input, much appreciated! Looks like i'll have to start experimenting with the hopper.
My only concern with the hopper is the orange peel texture in the videos looks pretty "textured". My walls seem to be more of a "mild-texture", pretty smooth, but you can definitely see theres a texture there. Will the texture subside, or smooth out a bit after prime and paint?
Also - should I be priming before i do the texture? or after?
Thanks again!
Old 06-20-2016, 05:45 PM   #5
Rewards Points: 144
No it won't after prime and paint.You have to experiment before doing it.Less mud ,move quicker ,thinner mud,different tips and setting on the hopper..Experiment on some scrap.There is a learning curve.That's why I do all of it in any given house in place of having one of my others guys do part of it.It's not that I am better but we all have a different feel for it.Although the differences are subtle and the HO may never see it.I don't like taking that chance.
Old 06-24-2016, 06:18 PM   #6
Rewards Points: 4,792
I've had very good success with the Wagner Power Tex - an electric version that doesn't require an air compressor. I use it for popcorn, but it has an orange peel setting as well - I just haven't tried that yet.
jeffnc is offline   Reply With Quote
Old 07-04-2016, 02:37 PM   #7
Rewards Points: 310
I think the cans are best for diy person on small projects. Use the water base "pro" cans and practice on a piece of scrap drywall. It will not be exact match as that is achieved by the original spray setup and the guy who did it that day, but it can be close enough that no one ever notices. You can easily wipe off the practice area before it sets until you get the spray nozzle adjusted, also, easier to use multiple passes to build up to desired look.
Not a pro, just a diy perspective
PandJ is offline   Reply With Quote
How to create a skip trowel texture (Photos/Video) Sir MixAlot How To Guides 1 10-15-2016 05:05 PM
do you have to tape joints? begal Drywall & Plaster 34 08-09-2015 09:42 AM
Texture over drywall repair tarrbaby Drywall & Plaster 2 09-11-2011 05:18 PM
Toping Compound for texture....before or after drywall primer? yummy mummy Building & Construction 6 05-04-2008 11:57 PM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 04:38 PM
