Drywall taping question
2K views 3 replies 4 participants last post by  lrobertstoner
On one wall the horizontal seam was taped but has bubbled the length of the sheet. What was the cause, ... not enough mud, too dry, too much of a gap between boards? And ... how best to fix this? Remove and re-tape or is there another trick of the trade?
It could also be moisture, but unless you see some staining, I would just treat it as a dry joint.
Pull it off and retape.
Ron
#3 · (Edited)
It could be that who ever taped it didn't get enough mud under the tape, but it could also be that you have an edge that has been fractured. In other words damage from handling. Usually a good drywaller will look for problems in the sheetrock and fix them as they are taping. But it is impossible to find everything. So be carefull, if you retape it and the damage is still there, it will look just like it does now. If you are going to work on it, take a knife and cut into the bubble. If tape comes off showing that it hadn't been mudded, like it had and air pocket, then you tear the tape off and retape, always getting rid of any loose material. If it is damaged sheetrock, when you cut into it, the gysum with fall out in powder, and pieces. Then you have to cut out all loose material, prefill and retape. There is one more thing that it can be and that is if the bubble has strength and integrity, then it is a factory problem that made its way through the inspection process. In that case you have to split the seam with at least a 12" knife, meaning passes of mud on each side of the tape to try and get the bump to hide. Trying to round it off so it isn't so noticeable.
