#1 |
Drywall tape with cement
my garage has drywall panels in the cieling and cement walls. would it be proper to use a drywall tape in the corners of the wall/cieling or should something else be used because of the cement. thanks in advance.
#2 |
Why not fasten some moulding in the corner to the ceiling and or wall with some construction adhesive? Drywall tape could do the job, but where do you stop mudding?
when it comes to breakfast, the chicken is dedicated, the pig is committed. LMASD |
#3 |
Get Tear-Away bead or Flat tear away. slide it tight to the block wall. Buy some spray glue to install it spray the drywall and the tear waay bead with the glue and just press on.
http://www.trim-tex.com/catalog/lbeads.htm Use the Tear away only if you have about 1/8" to 3/8" gap between the wall and the drywall. If drywall is tight use the flat tear away or just use the regular one and cut off the part that slips behind the drywall. If you have a bigger gap you might have to go and fill the gaps with some dura bond first Then just tape the bead in. That will look the best. Use a scrap piece of cardboard box and place that tight againt the corner of the rock and wall so you get no glue onto the block wall it could get messy if you don't no how to spray. Good luck |
| Display Modes | |
| Cement board meets drywall? | CowboyAndy | Drywall & Plaster | 8 | 12-25-2010 09:29 PM |
| drywall tape coming off | jlajla24 | Drywall & Plaster | 5 | 12-04-2008 10:27 PM |
| How to use non-adhesive drywall tape? | tripower | Building & Construction | 1 | 05-28-2007 10:29 AM |
| Drywall Mudding - Tape Lifting | Drywall_Dummy | Building & Construction | 5 | 09-06-2005 12:53 PM |
| Siding: Cement Vs. Cedar | Grumpy | Remodeling | 5 | 03-19-2005 02:07 PM |
