Drywall Tape - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-04-2011, 08:59 PM   #1
Rewards Points: 81
Drywall Tape
I have finished sanding my 2nd coat of joint compound and I have some small sections where I sanded a bit too much and have a few small areas of the tape showing --- very minor. Form past experience I know if I try to "touch up" these areas with another coat of compound, when I sand it will end up being a very smooth/glassy finish, and may even show up as a patch with the final topcoat of paint. Can I primer my walls, allow the primer to dry for a few days, then go back and put another skim coat over the couple of small places where the tape is showing? Re-prime the walls then topcoat?
cougar01 is offline   Reply With Quote
Old 04-04-2011, 09:25 PM   #2
Buy a good primer at a apron store .Put on one good coat first you may not see it. Don't rely on on paint with primer in it if the walls have never been painted.
Roboil is offline   Reply With Quote
Old 04-05-2011, 11:27 AM   #3
Rewards Points: 81
I'll be using a "new drywall" primer. Have some tape to cover back up and some imperfections to fix, but didn't want to "spot patch" over the existing compound until I applied primer. I am afraid of screwing up the entire area(s) if I just spot patched before priming. Assuming that my method to "fix" is acceptable? That is, prime the walls then go back with joint compound to skim coat any imperfections and exposed tape?
Old 04-05-2011, 04:38 PM   #4
cover exposed tape with a skim coat do not sand to much just lightly
nock down any edges you may see then prime and paint the glassy effect is from burning the wall or tape with the sand paper
you may prime and paint first then touch up then repeat process of prime and paint but that seems like alot of work or double work
you should be fine refinish then prime
one question i would ask is this tape humped away from wall or did you just get over abitious and sand too much
good luck
lrobertstoner is offline   Reply With Quote
Old 04-05-2011, 07:21 PM   #5
Rewards Points: 81
No humps. Tape is adhered to the wallboard. Just got over ambitious.
Old 04-05-2011, 08:59 PM   #6
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Just curious.....why are you sanding 2nd coat?
tcleve4911 is offline   Reply With Quote
Old 04-06-2011, 10:12 AM   #7
Drywall contractor
Rewards Points: 1,070
I think he's referring to second coat over the tape perhaps?? As long as there are no actual edges, the tape should paint out fine. It is a "paintable" surface. Put a good drywall primer on and if you don't feel any roughness or edges, you're fine.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
The Following User Says Thank You to bjbatlanta For This Useful Post:
tcleve4911 (04-06-2011)
Old 04-06-2011, 07:09 PM   #8
if it is smooth to touch, primer will cover. If you sanded right to the tape and can feel the bumps, more mud.
painter162 is offline   Reply With Quote
First time taping - Tape has air under it theedudenator Drywall & Plaster 16 04-22-2010 12:13 AM
Puckered Drywall tape line Chemist1961 Building & Construction 2 02-10-2010 12:55 PM
Drywall Tape? photosbyvj Drywall & Plaster 8 09-11-2009 10:17 PM
Drywall tape sticking out vancouver Drywall & Plaster 5 09-08-2009 11:04 PM
Repairing drywall tape bcouch Drywall & Plaster 2 09-08-2009 04:19 PM
